NO 20241228
Baz
NO 20241228
Baz
Interesting. Had 20241228 on sd card. CE updated to 20250103
Corrupt rebooting in 120 second or similar.
Can not resurrect system .
Also tried to remove old CE partitions from sd card. Cant do it.
Formatters say sd card is now write protected?
Is there Something wrong with xxxx103?
Will not repeat update unless others can say its ok.
Nothing wrong with it.
uSD in g12b at least is something wrong right now.
Kernel modify some regulator so u-boot doesnât see the uSD on reboot. A DC power pull/plug do fix it.
@Portisch, what S928X hardware are you using to do your tests?
Build from 31.12.2024 was ok for you ? For me it was first time when started with new kernel on device am6plus and was very good stabile CE22NO. I am only on this build.
[khadas VIM4, Sandisk 64GB and 32GB extreme pro]
Sorry, if it is old crap for you and i missed some answers:
20241220 was the last edition (and of course the NE version), wich works after copying to an SD card.
After inserting and booting the screen stays in the debugging shell on:
âŚcould not mount /dev/mmcblk1p1
This is the internal flash with an older release of CoreELEC and was not used if booting from SD card (mmcblk0p1 and p2).
I have tried update installations wich will fail with an black screen after rebooting and prepare now new and unused SD cards to test, if NO will run again.
Any hints?
Homatics 4K plus, after udpate to android 14 and install nightly CE image on videos is green and unable to use 4k resolution, i tried dtb sc2_s905x4_sei_smb_280 and sc2_s905x4_4g_1gbit. no changes faulty image green and bad colors are still there
Finally got my N2 to boot with 20241230.tar on eMMC:
Installed 20240820-Odroid_N2.img (kernel .119) from my archive â OK
Updated with 20241230.tar (kernel .137) â Not OK, stops after logo on black screen
Changed new dtb.img with old from original installation â OK
It boots, reboots, power on/off all work.
So you have put with keyboard the command dmesg | less and after take photo from outputs.
Booting of build 20250103 from SD after update or ordinary restart is going on AM6plus with s922XJ (g12b).
https://paste.coreelec.org/AdmiringHawkins
https://paste.coreelec.org/MarriageSorcerer
https://paste.coreelec.org/HooeyShame
OK, there is realy a lot of stuff, before iâm doing this: is the line with the unknown boot source from interist? Wich parts of info do you need from all that stuff?
(new users could only do 1 embedded shot at post?)
errors and sdio errors you have to look for. Unknown kernel parametrs is normal for CE ![]()
Tomorrow with nightly 20250105 hopefully N2 should boot normal like on NG again.
Also ATV14 is maybe support by CE-NO by @vpeter.
The implementation in CE is not finished yetâŚ
ATV14 is another reason for CE-NG EOL as this EROFS file system is not supported by the old 4.9 kernel.
@vpeter
Thanks for find the correct layout for the atv14, the system info page hdd section is clear now.
Also the reboot to android working now.
There is lot of bugs, but most of the files playable.
Thanks to the team.
Sure we have. It doesnât matter what S5 is used.
So I guess that means for devices with the S905X4 such as the (Dune) Homatics, you need to stay on ATV12 if you want to continue using NG with FEL support?
[quote=âPortisch, post:1189, topic:46663â]
20250105
[/quote]Unfortunately, the 20250105 does not boot either.
I have exchanged the dtb.img (from 06122024), but CE is booting with a distorted display on TV. here is the 20250105 log:
https://paste.coreelec.org/AntiqueCauses
https://paste.coreelec.org/RegularPelican
Itâs booting but you trigger the black screen bug.
Well, not really, the image does not start the installation on eMMC; after logo it stops on black screen with no blue Led activityâŚ
Changing dtb.img with my old one from â20240820-Odroid_N2.imgâ the installation starts and installs - Happy New Year ![]()
