the latest nightly build with the default drivers
http://ix.io/1M7h
You are still using old dtb with GPIOZ_5 issue.
[ 86.438227@3] c9410000.ethernet is using the pin GPIOZ_5 as pinmux
[ 86.438233@3] pinmux-gxbb c1109880.pinmux: request() failed for pin 19
[ 86.438237@3] pinmux-gxbb c1109880.pinmux: pin-19 (banks:141) status -22
Copy gxbb_p200_1G_sen5.dtb (39.9 KB) to SD card and rename it to dtb.img.
you are magicien bro. (i use your dtb every time but this lastest is very good).
thanks
[ 87.672173@3] dvb_meson dvb.51: Checking for AVL6211 DVB-S/S2 demod …
[ 87.672526@3] i2c i2c-1: AVL6211+AV2011 DVB-S/S2 successfully attached
[ 87.672532@3] dvb_meson dvb.51: Total DVB modules found: 1
[ 87.853454@2] aml_wifi wifi.32: [extern_wifi_set_enable] WIFI Enable! 234
[ 88.153584@3] dvbdev: DVB: registering new adapter (dvb_meson)
[ 88.155907@3] DMX: dmx0 irq:55
[ 88.159919@3] DMX: ts0 irq:51
[ 88.159982@3] DMX: ts1 irq:-1
[ 88.160014@3] dvb_meson dvb.51: DVB: registering adapter 0 frontend 0 (Availink AVL6211+AV2011 DVB-S/S2)…
[ 88.160165@3] Meson DVB frontend(s) registered successfully.
sorry but i cant make sat search?
I fellow Tvheadend installation process but no scan is done.
mpegts: 10714H in Astra 1 - tuning on Availink AVL6211+AV2011 DVB-S/S2 #0 : DVB-S #0
diseqc: failed to send diseqc cmd (e=Invalid argument)
http://ix.io/1Ml6
[ 223.006909@0] dvb_frontend: dvb_frontend_get_frequency_limits: frequency interval: tuner: 0…0, frontend: 950000000…2150000000
[ 345.692521@0] i2c i2c-1: [aml_i2c_xfer] error ret = -5 (-EIO)
[ 345.692570@0] i2c i2c-1: token 0, master_no(1) 300K addr 0xc
[ 345.692875@0] i2c i2c-1: [aml_i2c_xfer] error ret = -5 (-EIO)
[ 345.692906@0] i2c i2c-1: token 0, master_no(1) 300K addr 0xc
[ 345.693209@0] i2c i2c-1: [aml_i2c_xfer] error ret = -5 (-EIO)
[ 345.693239@0] i2c i2c-1: token 0, master_no(1) 300K addr 0xc
[ 345.693265@0] i2c i2c-1: i2c wr failed=-11
[ 448.711800@1] dvb_frontend: dvb_frontend_get_frequency_limits: frequency interval: tuner: 0…0, frontend: 950000000…2150000000
[ 452.907934@1] dvb_frontend: dvb_frontend_get_frequency_limits: frequency interval: tuner: 0…0, frontend: 950000000…2150000000dvb_frontend: dvb_frontend_get_frequency_limits: frequency interval: tuner: 0…0, frontend: 950000000…2150000000
This is strange. In initial communications demod is answering on addr 0xc. You can see in log:
[ 83.933627@1] dvb_meson dvb.51: Checking for AVL6211 DVB-S/S2 demod ... [ 83.933990@1] i2c i2c-1: AVL6211+AV2011 DVB-S/S2 successfully attached [ 83.933996@1] dvb_meson dvb.51: Total DVB modules found: 1 [ 83.937691@1] dvbdev: DVB: registering new adapter (dvb_meson) [ 83.943507@0] DMX: dmx0 irq:55 [ 83.958090@1] DMX: ts0 irq:51 [ 83.958157@1] DMX: ts1 irq:-1 [ 83.958194@1] dvb_meson dvb.51: DVB: registering adapter 0 frontend 0 (Availink AVL6211+AV2011 DVB-S/S2)... [ 83.961952@1] Meson DVB frontend(s) registered successfully. [ 84.041137@0] i2c i2c-1: [aml_i2c_xfer] error ret = -5 (-EIO) [ 84.041151@0] i2c i2c-1: token 0, master_no(1) 300K addr 0xc [ 84.041206@0] i2c i2c-1: [aml_i2c_xfer] error ret = -5 (-EIO) [ 84.041211@0] i2c i2c-1: token 1, master_no(1) 300K addr 0xc [ 84.041487@0] i2c i2c-1: [aml_i2c_xfer] error ret = -5 (-EIO) [ 84.041492@0] i2c i2c-1: token 0, master_no(1) 300K addr 0xc [ 84.041497@0] i2c i2c-1: i2c wr failed=-11
I prepared dvb-latest addon with more debug info. Install this addon MEGA and reboot box.
http://ix.io/1MqK
[ 183.994543@3] i2c i2c-1: avl6211_i2c_repeater_get_status: failed=-22
[ 183.994553@3] i2c i2c-1: AV2011_I2C_write: failed=-22
[ 183.994558@3] i2c i2c-1: av2011_lock: failed=-22
[ 183.994563@3] i2c i2c-1: avl6211_set_frontend: failed=-22
[ 184.079673@0] i2c i2c-1: avl6211_diseqc_switch_mode: failed=-22
[ 184.079685@0] i2c i2c-1: avl6211_diseqc_send_mod_data: failed=-22
[ 184.079689@0] i2c i2c-1: avl6211_send_diseqc_msg: failed=-22
[ 184.079939@0] dvb_frontend: dvb_frontend_get_frequency_limits: frequency interval: tuner: 950000000…2150000000, frontend: 950000000…2150000000
[ 184.165041@0] i2c i2c-1: avl6211_diseqc_switch_mode: failed=-22
[ 184.165052@0] i2c i2c-1: avl6211_diseqc_send_mod_data: failed=-22
[ 184.165057@0] i2c i2c-1: avl6211_send_diseqc_msg: failed=-22
There is a issue with tuner. Most likely there isn’t Airoha AV210x tuner. I can’t support dvb tuner without knowing chipset used for it.
The DVB board looks very similar to Wetek Play 2xDVB-S2 tuner board with Eardatek tuners.
But WP uses Eardatek EDS-11030FNPVA EDS-11030FNPA.pdf.
In your box is EDS-11270NPVA currently End-Of-Sale, as Eardatek offers following tuners:
http://ww.eardatek.com/HalfNIMTuner1.shtml.
You can only open tuner box to see chip used for tuner.
It is the EDS-11270FNPVA tuner with airoha av2026
Airoha AV2026
Airoha AV2012
There is minor difference in pin4 (RFN-) and the name of pin 13 (TEST=>PD).
Here Airoha AV2026 document.
hi, i have an amiko a4k v5.1.1 and i have tried all the dtb. img and there are no dvd adaptrs, and i really want to use coreelec. thanks for all team coreelec.
greeting
With dvd you mean dvb? Did you try the various DVB drivers under Add-ons -> CoreELEC Module Drivers?
yes sir, I tried all three
As I’m not a dev and I can’t really help you but in general it would be good to post some logs. Just a guess but dmesg and lsusb logs might be useful with the dtb you think is the most correct one.
As you’ve already posted this same question 11d ago in the Amiko A4 thread I would recommend continuing over there instead of taking over this thread as well.
What backend are you using?
Do the dvb adapters show up in that?
Is it a combo box (DVB-T & DVB-S) you have?
