i try the coreelec on my android box and the DVB not found.
The device made with Amlogic S905 & tuner AVL6211 (used in many amlogic devices).
and i have dtb.img extracted from its original firemware of android.
the coreelec booted and worked with gxbb_p200_k1_plus.dtb & gxbb_p200_1G_100M.dtb & many other device tree but the dvb not found
i ask for any help to make the dvb worke for this device.
I look in my crystal ball and I see gxbb_p200_1G_1Gbit_ks2.dtb
this dtb.img i get it from its android software
using gxbb_p200_1G_1Gbit_ks2.dtb
make the LAN not work.
i cant access the tvheadend page or download any addons
I found that the dtb.img little bit similar to K1 (AVL6211&LAN&S905) and much more for K2 but this last is S905 and cant boot at all.
Pls provide kernel log dmesg | paste
for both dtb’s. Try to use wifi connection for ks2 version. I think your box is Sen5 SH6B7FA https://www.cnx-software.com/2017/04/03/sen5-dual-tuner-android-set-top-box-review-part-1-unboxing-and-teardown/#sen5-sh6b7fa-tv-box-teardown
the device is the clone of istar S1 V2 & istar S10 V2 & sen5 SH6B5A clones accept the same software
gxbb_p200_1G_sen5.dtb
http://ix.io/1JWw
http://ix.io/1JWx
http://ix.io/1JWI
http://ix.io/1JWK
I dont see the AVL6211 in the kernel log.
the coreelec doesn’t support this driver or what?
this source code wirh AVL6211 driver maybe can help
this source code is found too
and this is a firemware
and there is some enigma 2 source code with avl6211 driver like openpli
I don’t need sources for AVL6211. This driver is already in CE. Wetek Play 2 uses this chip for DVB-S.
I need kernel log immediatly after rebooting box (< 30 sec), otherwise log is overwritten with a chunk. I need also report what is working with gxbb_p200_1G_sen5.dtb
ethernet, wifi, bluetooth,…
I don’t need Kodi log !!!
how to find the kenel log ?
dmesg | paste
how to make dvb work
this is part of log using gxbb_p200_1G_sen5.dtb
[ 75.464320@1] dvb_meson dvb.51: Found i2c-1 adapter: aml_i2c_adap1
[ 75.464334@1] dvb_meson dvb.51: ts0: parallel
[ 75.464402@1] dvb_meson dvb.51: ts0_control: 0x0
[ 75.464445@1] dvb_meson dvb.51: dev_name=wetek-dvb
[ 77.894990@1] dvb_meson dvb.51: Checking for AVL6211 DVB-S/S2 demod …
[ 77.895121@1] i2c i2c-1: [aml_i2c_xfer] error ret = -5 (-EIO)
[ 77.895153@1] i2c i2c-1: token 1, master_no(1) 300K addr 0xc
[ 77.895237@1] i2c i2c-1: [aml_i2c_xfer] error ret = -5 (-EIO)
[ 77.895266@1] i2c i2c-1: token 1, master_no(1) 300K addr 0xc
[ 77.895348@1] i2c i2c-1: [aml_i2c_xfer] error ret = -5 (-EIO)
[ 77.895377@1] i2c i2c-1: token 1, master_no(1) 300K addr 0xc
[ 77.895406@1] i2c i2c-1: i2c wr failed=-11
[ 77.895435@1] dvb_meson dvb.51: Failed to find AVL6211 demod!
[ 78.054984@1] dhd_open: Enter ffffffc0233a3000
and after 80.33
[ 80.335305@0] dvb_meson dvb.51: Total DVB modules found: -1
[ 80.338303@0] dvbdev: DVB: registering new adapter (dvb_meson)
[ 80.340384@0] DMX: dmx0 irq:55
[ 80.341772@0] DMX: ts0 irq:51
[ 80.341843@0] DMX: ts1 irq:-1
[ 80.341886@0] Meson DVB frontend(s) registered successfully.
I added serial transfer support for AVL6211. You have upgrade to the latest nightly builds and switch to dvb drivers addons, use dvb-latest. Update dtb gxbb_p200_1G_sen5.dtb (39.9 KB).
thanks for helping
the DVB not found and still real problem with the same message at startup “you are using an unsupported DTB”
i try the gxbb_p200_1G_sen5.dtb (39.9 KB).
with the default drivers
http://ix.io/1LY1
with the dvb driver from lastest kernel.
http://ix.io/1LXW
Sorry, I used GPIOZ_5 instead of GPIOAO_5 for demod reset pin. It is necessary set correct reset pin, otherwise demod is in reset status by default. Try gxbb_p200_1G_sen5.dtb (39.9 KB).
