Tanix X3 is available for pre-order too but it doesn’t have gigabit ethernet.
Is 1gb ethernet really required other than for the jellyfish. I haven’t come across anything that requires >45GB an hour bandwidth. With 200M of buffering setup in the advanced settings there would have to be a lot of fast action for 100Mb not to keep up.
I’ve had issues in a few titles with 100M, even with a large buffer.
I always remux (MKVToolnix) stuff and remove all unwanted audio and subtitle tracks this can reduce the size by 50% but never had any problems. Having said that I have a 1Gb backbone (switch) so I can get the full 100M from the switch even when there is a lot of other traffic.
I guess it could also also depend on the protocol.
I know that I had issues with Ghost In The Shell remux, especially somewhere at the 4-6 minute part.
But it did work ok most of the time, just not all of the time, which was enough for me to just add a $5 gigabit USB ethernet adapter.
Yea Its not the end of the earth to only have 100Mb if the box is cheap enough and you can get a supported ethernet cheap enough rather than a built in one that may never be supported
I just bought mine to have some fun!
GB + 32 4 GB + 2.4G & 5.8 GHz Dual Wifi + BT4.1
@TheCoolest
uhd bluray movies use up to 128Mbps bitrate so gigabit is necessary to play all of them smoothly via ethernet.
In theory. Never seen anything close to it.
But I agree 100 Mbps is not enough.
Amlogic S905X4
Specifications:
- CPU – Quad-core Arm Cortex-A55 processor
- GPU Arm Mali-G31MP2
- Video
- 4Kp75 H.265, VP9, AVS2
- 4Kp120 AV1
- HDR support
- Smart Audio
- Voice Activity Detector (VAD)
- Asynchronous Sample Rate conversion (ASRC)
- Equalizer (EQ)
- Dynamic Range Compression (DRC)
- 2x DSP for audio front end (AFE) and wake word engine (WWE)
Amlogic S905X4 looks like an update to Amlogic S905X3 with AV1 codec support, and maybe extra audio features.
Does anybody know if this X96 has an ON/OFF switch? Or it can only be switched on and off via remote control?
Thanks!
Just one question @anon88919003 on this subject, as I many here use translator.
Not to be doubted here or misunderstood.
Will Coreelec support Chinese S905X3 box?
or
Will Coreelec support S905D3 only khadas?
That question is more complicated to answer than a simple yes or no.
We want to support all devices and we will eventually but right now only the KVIM3L is supported for technical reasons.
HK1 X3 box has gigabit ethernet, costs just £29 delivered!!!
I really hope support for this box is added as it is so cheap.
DDR 3 or DDR 4 Ram ??
X96 MAX+ is LPDDR3, as same as the most of others s905x3, because them are too cheap…
Do those 905X3 boxes support HD Audio and HDR 2 SDR tonemapping?
Yes, works the same as in all the other SoCs.
So there will be no visible difference in terms of tonemapping to Odroid N2 for eg?
4GB DDR3 ram.
