Amlogic VNC on Odroid C5 NO
Just wondering if I’m missing a setting or something with the VNC add-on on a C5 with NO.
The keyboard works to move around and select things but video over VNC is just the CE wallpaper (VNC on my Ugoos 6b+ with NG works like it always has still).
Thanks, the C5 is working great!!
I don’t know if it is related but when I create a screenshot on the C5 with ctrl-s it shows as black.
Same here with HK1 RBOX X50 Amlogic S905X5M(S905A) and s7d_s905x5m_4g_1gbit.dtb
Sorry for double posting
When you stop kodi (with systemctl stop kodi) the background on TV is the same that VNC
So, I think that VNC doesn’t listen the correct screen ID or Kodi use an other screen ID (like a 2nd screen even if there’s no dual screen)
