Android Box Options For 4k HDR, ATMOS AND DTS X from HDD
Hello everyone,
I’m new here I would like to ask your help with choosing the appropriate tv box for my setup
I have a samsung 7100 (capable of 4K HDR)
and a Pioneer YTP-076 ( Atmos and its dts X compatible)
I will play movies on my external HDD
I am searching for a tv box that will be able to play 4K HDR with passthrough via HDMI of DTS X and ATMOS with a stable version of CE budget around $75
Can someone point me toward the right post please
im a bit lost with all the specs
Thanks for your help
If you want something supported and reliable I would look at the Khadas VIM3L.
You can’t brick this box and should give you all the options you are looking for.
You can use passthrough for the audio and the box will output HDR10 using the nightly builds.
