So, it looks like Nextcloud is not running anymore. This was announced some months ago and since a couple of days ago the nextcloud container starts but does not really listen to the HTTPs port.
Indeed, it looks like its startup script (/storage/.kodi/addons/docker.linuxserver.nextcloud/bin/docker.linuxserver.nextcloud) has been intentionally broken:
ARCH=$(grep LIBREELEC_ARCH /etc/os-release | sed -E 's|.*\.(.*)"|\1|')
if [ "${ARCH}" = "arm" ]; then
echo '
**** You are using 32 bit userspace ****
**** Linuxserver has deprecated 32 bit images ****
**** https://info.linuxserver.io/issues/2023-07-01-armhf/ ****
**** This addon will not run on your system ****
sleep infinity
fi
I will try to just remove that sleep infinity line, but I wouldn’t be surprised if this doesn’t help either. So, the question is, do we have any other options available for running nextcloud (I’m using a Khadas VIM3l)?
As far as I understand, this SoC is 64 bit; I wonder, then, is there (or will there be) a 64 bit version of CoreELEC availbale?
