Are these Ugoos boxes legit?
Ugoos AM6B Plus
Looking to upgrade from my Minix U9-H to something that will give me Dolby Vision. Was wondering if anybody ordered these from Ali and if they are the real thing. Also, am I better off getting the AM6 pro or even the AM6+?
Any help would be very much appreciated. Thanks in advance.
Are you asking if the most recommended CE device is legit? :rofl: Or just specifically the listings on Aliexpress? Those prices seems pretty typical from when I last checked.
But yes, the AM6b Plus is one of the “best” UHD drive replacement boxes. It’s not the best “streaming” box, because it’s unlicensed and therefore won’t have access to apps such as Netflix, etc. But if you want to use it solely for CE to watch your UHD collection with Dolby Vision (as long as you install the dovi.ko file correctly), then yes it’s highly recommended.
You can check this thread for more details: Best device for Coreelec in 2024
