I just update to CE 9.0.0 on Odroid C2. None of my music files play, only movies. The only difference is moving from 8.99.2 to 9.0.0
AlleyCat
AlleyCat
No logs, no problem.
Read the forum guidelines and the post on how to report issues.
Someone else had a similar issue. Turned out to be a share addressing issue. If you can select and play the files via the file manager then it likely the Same.
Clean your music library and recreate the media sources.
