Hi guys,
I have strange problem with short audio dropouts while using CoreELEC with Ugoos AM6 Pro. The dropouts occur randomly and cannot be reproduced. Each time an dropout occurs, there is the same record in the kodi log: http://ix.io/2V1j
The log is for default audio configuration in Kodi, but the same situation also occurs with different audio setups. The box is connected to TV via HDMI, the HDMI cable replacement didn’t help. Also I don’t have the issue with Android and Kodi running on the same hardware and same video source.
I have the last CoreELEC version 9.2.7, but the problem occured also in previous versions. I did a fresh installation with no effect.
I would be grateful for any help.
