Hi Everyone,
I have my Headphones connected to the SPDIF Output and watch TV via the HDMI.
When I select the SPDIF Output, some videos like this one:
Audio
Format : E-AC-3 JOC
Format/Info : Enhanced AC-3 with Joint Object Coding
Commercial name : Dolby Digital Plus with Dolby Atmos
Codec ID : A_EAC3
Duration : 37 min 58 s
Bit rate mode : Constant
Bit rate : 768 kb/s
Channel(s) : 6 channels
Channel layout : L R C LFE Ls Rs
Sampling rate : 48.0 kHz
Frame rate : 31.250 FPS (1536 SPF)
Compression mode : Lossy
Stream size : 209 MiB (3%)
Language : English
Service kind : Complete Main
Default : Yes
Forced : No
Complexity index : 16
Number of dynamic objects : 15
Bed channel count : 1 channel
Bed channel configuration : LFE
Will have audio from both the SPDIF and the HDMI. Why? I didn’t even think it was possible to have audio via both at the same time!
Here are my Audio Setting for using the SPDIF Output:
Here is the debug file when playing the video above.
TIA
EDIT: This is interesting.
Setting the SPDIF as the output and before playing the video.
Ugoos:~ # amixer get 'Audio hdmi-out mute'
Simple mixer control 'Audio hdmi-out mute',0
Capabilities: pswitch pswitch-joined
Playback channels: Mono
Mono: Playback [on]
After starting to play the video.
Mono: Playback [off]
Ugoos:~ #
Seems playing the video is turning OFF the muting of the HDMI output.
