I have an external SSD and it works when i mount it with:
mount -o ro,force,defaults /dev/sda1 /media/Volume
But its not mounted by default when i boot CE.
I have to use ro,force because its NTFS and marked dirty, i can not switch the FS, unfortunately.
Anyone an idea how to get this working? What is the best approach? Some udev rule? Or autostart.sh? I am not sure what the “best” way is.
Fix it on Windows and will work automatically again.
just afraid that i have to boot windows then all the time when ntfs believes something “bad” happened. unfortunately, its a 4tb ssd and its quiet full. i have no other drive where i could temporarily store so much data to convert it to ext4… i’ll boot my windows machine in the next days and try and see how long it works.
I have had the same problem too, and windows said it needed to repair the disk (chkdsk).
Then the CE auto recognized the disk…SSD.
