However if I run autorun.sh manually via terminal, it works fine.
CoreELEC (official): 9.0.1 (Amlogic.arm)
CoreELEC:~ # cat /etc/*-release
NAME="CoreELEC"
VERSION="9.0.1"
ID="coreelec"
VERSION_ID="9.0"
PRETTY_NAME="CoreELEC (official): 9.0.1"
HOME_URL="https://coreelec.org"
BUG_REPORT_URL="https://github.com/CoreELEC/CoreELEC"
BUILD_ID="df47d9506043985aa1dd1f71a79cecd9dacd275d"
COREELEC_ARCH="Amlogic.arm"
COREELEC_BUILD="official"
COREELEC_PROJECT="Amlogic"
CoreELEC:~ # cat /storage/.config/autostart.sh
#!/bin/sh
hdparm -B 127 -M 254 -S 120 /dev/sda5
/storage/.opt/bin/python3 /var/media/sda5-usb-ST916031_0AS_536/discord/main.py
CoreELEC:~ # ls -l /storage/.config/autostart.sh
-rwxr-xr-x 1 root root 133 Mar 8 15:20 /storage/.config/autostart.sh
CoreELEC:~ #
Before calling python3 add sleep 10
- adjust value appropriately. I assume disk is not mounted yet when script starts.
Instead of sleep you could add some loop and wait until disk is mounted.
I put 30 seconds sleep, didn’t work
Then use this instead of a sleep
while [ ! -d /var/media/sda5-usb-ST916031_0AS_536 ]; do
sleep 1
done
Nope, not working at boot. Starting manually works fine.
Using username "root".
# CoreELEC #
# https://coreelec.org #
CoreELEC:~ # sh /storage/.config/autostart.sh
CoreELEC:~ #
/dev/sda5:
setting Advanced Power Management level to 0x7f (127)
SG_IO: bad/missing sense data, sb[]: 70 00 01 00 00 00 00 0a 00 00 00 00 00 1d 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
setting acoustic management to 254
SG_IO: bad/missing sense data, sb[]: 70 00 0b 00 00 00 00 0a 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
setting standby to 120 (10 minutes)
APM_level = 127
acoustic = not supported
W,2019-03-08 16:27:16,879,discord.client,144: PyNaCl is not installed, voice will NOT be supported
I,2019-03-08 16:27:16,897,__main__,260: Starting BOT...
W,2019-03-08 16:27:18,220,discord.gateway,417: Unknown event SESSIONS_REPLACE.
I,2019-03-08 16:27:18,509,__main__,62: client.user.name:********* client.user.id:***************************
#!/bin/sh
sleep 1
done
Then your values from hdparm are overwritten somewhere else. Try my loop + add extra sleep 10 after loop is done.
not, not working. I think the problem is not delay or external hdd not getting mounted.
I think the problem is autorun.sh is not getting executed at all
#!/bin/sh
dmesg > /storage/dmesg.log
sleep 1
done
sleep 10
And /storage/dmesg.log is not being created
I’m going to try a fresh install
Can you post result of
systemctl status kodi-autostart.service -l --no-pager
I disabled kodi and eventlircd because I’m using tvheadend server only.
Does this affect autorun.sh?
CoreELEC:~ # systemctl status kodi-autostart.service -l --no-pager
● kodi-autostart.service - Kodi user autostart script
Loaded: loaded (/usr/lib/systemd/system/kodi-autostart.service; disabled; vendor preset: disabled)
Active: inactive (dead)
autostart.sh is execute from kodi-autostart.service which is needed by kodi.
No kodi -> no autostart
Try
cp /usr/lib/systemd/system/kodi-autostart.service /storage/.config/system.d
sed -i "s|WantedBy=kodi.service|WantedBy=graphical.target|" /storage/.config/system.d/kodi-autostart.service
Damn! I’ve been trying to solve this for two days
So what are my options to run my discord bot at boot? Would systemd service work?
Yes, try service like this - with different ExecStart
[Unit]
Description=autostart script
Before=kodi.service
After=network-online.target graphical.target
ConditionPathExists=/storage/.config/autostart.sh
[Service]
Type=oneshot
Environment=HOME=/storage
ExecStart=-/bin/sh -c ". /etc/profile; exec /bin/sh /storage/.config/autostart.sh"
RemainAfterExit=yes
[Install]
Now I’m starting my discord bot as systemd service like below. Thank you!
[Unit]
Description=My Discord Bot
After=network-online.target multi-user.target
ConditionPathExists=/var/media/sda5-usb-ST916031_0AS_536/discord/main.py
[Service]
Type=simple
ExecStart=/storage/.opt/bin/python3 /var/media/sda5-usb-ST916031_0AS_536/discord/main.py
[Install]
WantedBy=multi-user.target
