please my tv box with amlogic s905w, 1gb ram, 8gb internal and availink avl6221 dvb s2 tuner dont detect dvb tuner in the tvheadend. Am I using wrong dtb file or coreelec dont support avl6221 dvb tuner? Here is the converted dts file.
dts.dts (55.0 KB)
Did you check the list of devices that CE supports before buying your Availink ?
have you installed and tried the three DVB modules that are available in the CE addons repositiory ? If you have and none work then CE doesn’t support your particular hardware.
it seems availink provides open source driver for avl62x1 tuner.
Will that help get the driver into coreelec?
