Tested with the 8.95.0 release on my Mecool Pro+ (S905X - 2 GB of RAM). Here is what I get with dmesg|grep dvb:
[ 14.071993@1] kernel-overlays-setup: processing conf /storage/.cache/kernel-overlays/50-driver.dvb.crazycat.conf
[ 14.116042@1] kernel-overlays-setup: added modules from /usr/lib/kernel-overlays/driver.dvb.crazycat/lib/modules/3.14.29
[ 16.871797@2] Modules linked in: dvb_usb_it913x(+) dvb_usb_v2(O) dvb_core(O) ir_rc6_decoder(O) ir_nec_decoder(O) wifi_dummy meson_ir(O) rc_core(O) amlvideodri(O) videobuf_res(O) videobuf_core(O) videodev(O) dwc_otg fbcon bitblit softcursor font
[ 16.907942@2] PC is at it913x_io+0x70/0x2b0 [dvb_usb_it913x]
[ 16.913537@2] LR is at it913x_io+0x5c/0x2b0 [dvb_usb_it913x]
[ 18.056959@2] [<ffffffbffc0f9180>] it913x_io+0x70/0x2b0 [dvb_usb_it913x]
[ 18.063594@2] [<ffffffbffc0fa014>] it913x_return_status+0x44/0x118 [dvb_usb_it913x]
[ 18.071183@2] [<ffffffbffc0fa484>] it913x_identify_state+0x2c/0x50c [dvb_usb_it913x]
[ 18.078860@2] [<ffffffbffc0ef65c>] dvb_usbv2_probe+0x1b4/0xfe8 [dvb_usb_v2]
[ 18.131990@2] [<ffffffbffc0fd020>] $x+0x20/0x2c [dvb_usb_it913x]
[ 18.398160@3] usb 1-2.3.1: dvb_usb_v2: found a 'DVBSky S960/S860' in warm state
[ 18.423871@3] usb 1-2.3.1: dvb_usb_v2: will pass the complete MPEG2 transport stream to the software demuxer
[ 18.464419@3] dvbdev: DVB: registering new adapter (DVBSky S960/S860)
[ 18.466472@3] usb 1-2.3.1: dvb_usb_v2: MAC address: 00:17:42:54:96:0c
[ 18.598155@3] Registered IR keymap rc-dvbsky
[ 18.634793@3] usb 1-2.3.1: dvb_usb_v2: schedule remote query interval to 300 msecs
[ 18.636821@3] usb 1-2.3.1: dvb_usb_v2: 'DVBSky S960/S860' successfully initialized and connected
[ 18.658253@3] usbcore: registered new interface driver dvb_usb_dvbsky
For a comparison, here is what I get with zszaq’s LibreELEC 8.2 that works perfectly fine:
[ 28.823216@3] dvb_usb_af9035 1-1:1.0: prechip_version=83 chip_version=02 chip_type=9135
[ 28.839634@3] usb 1-1: dvb_usb_v2: found a 'Avermedia A835B(3835)' in cold state
[ 28.844662@3] usb 1-1: dvb_usb_v2: downloading firmware from file 'dvb-usb-it9135-02.fw'
[ 28.982725@3] dvb_usb_af9035 1-1:1.0: firmware version=3.40.1.0
[ 28.982756@3] usb 1-1: dvb_usb_v2: found a 'Avermedia A835B(3835)' in warm state
[ 28.982764@3] dvb_usb_af9035 1-1:1.0: [0] overriding tuner from 38 to 60
[ 29.043132@3] usb 1-2.3.1: dvb_usb_v2: found a 'DVBSky S960/S860' in warm state
[ 29.047118@3] usb 1-1: dvb_usb_v2: will pass the complete MPEG2 transport stream to the software demuxer
[ 29.047205@3] dvbdev: DVB: registering new adapter (Avermedia A835B(3835))
[ 29.048256@3] dvbdev: dvb_create_media_entity: media entity 'dvb-demux' registered.
[ 29.050375@3] usb 1-2.3.1: dvb_usb_v2: will pass the complete MPEG2 transport stream to the software demuxer
[ 29.050425@3] dvbdev: DVB: registering new adapter (DVBSky S960/S860)
[ 29.051715@3] usb 1-2.3.1: dvb_usb_v2: MAC address: 00:17:42:54:96:0c
[ 29.052723@3] dvbdev: dvb_create_media_entity: media entity 'dvb-demux' registered.
[ 29.179284@2] dvbdev: dvb_create_media_entity: media entity 'Afatech AF9033 (DVB-T)' registered.
[ 29.297705@1] dvbdev: dvb_create_media_entity: media entity 'Montage Technology M88DS3103' registered.
[ 29.424698@0] usb 1-1: dvb_usb_v2: schedule remote query interval to 500 msecs
[ 29.424716@0] usb 1-1: dvb_usb_v2: 'Avermedia A835B(3835)' successfully initialized and connected
[ 29.455244@0] usbcore: registered new interface driver dvb_usb_af9035
[ 29.483044@1] Registered IR keymap rc-dvbsky
[ 29.495048@1] usb 1-2.3.1: dvb_usb_v2: schedule remote query interval to 300 msecs
[ 29.495067@1] usb 1-2.3.1: dvb_usb_v2: 'DVBSky S960/S860' successfully initialized and connected
[ 29.507175@1] usbcore: registered new interface driver dvb_usb_dvbsky
[ 33.646782@3] m88ds3103 2-0068: downloading firmware from file 'dvb-demod-m88ds3103.fw'
lsusb:
Bus 001 Device 006: ID 0572:6831 Conexant Systems (Rockwell), Inc. DVBSky S960 DVB-S2 tuner
Bus 001 Device 002: ID 07ca:3835 AVerMedia Technologies, Inc. AVerTV Volar Green HD (A835B)
Thanks in advance.
