I’m loosing my mind trying to understand why my simple bash script is running differently when launched manually and launched from crontab.
Script is performing 3 steps:
# STEP 1: remove folders older than 14 days first
find /storage/backup/DBDump -type d -ctime +14 -exec ls -d {} \; >/storage/backup/Temp/foldersToDelete.out
exec < /storage/backup/Temp/foldersToDelete.out
while read item ; do
if [[ -d $item ]] ; then
CURRDATE=`date "+%Y-%m-%d %H:%M:%S"`
rm -rf $item && echo [$CURRDATE] deleted folder: $item >> /storage/backup/Temp/foldersDeleted.out
fi
done
# STEP 2: create subfolder
CURRDIR=`date "+%Y-%m-%d"`
mkdir /storage/backup/DBDump/$CURRDIR
# STEP 3: dump DB and copy it to the created subfolder
/storage/.kodi/addons/service.mariadb/bin/mysqldump -h<my-NAS-IP> -P3307 -ukodi -p<password> MyMusic72 > /storage/backup/DBDump/$CURRDIR/MyMusic72.sql
/storage/.kodi/addons/service.mariadb/bin/mysqldump -h<my-NAS-IP> -P3307 -ukodi -p<password> MyVideos116 > /storage/backup/DBDump/$CURRDIR/MyVideos116.sql
When launching this script manually all 3 steps are completed.
When that script is added to the crontab then second and third step are completed but the first one is not.
The line launched in cron:
does not generate the list of folders for deletion!
Output file:
is created but is just empty.
When I launch this single line in SSH:
then the output file contain the folder that will be deleted.
Why?
Please help!
