Dears
When I play an ISO bluray file with BD J MENUS, and navigate through the menu of the movie, I can do it with the remote control without issues.
However, when I start the movie, then I cant fast forward, pause, change chapter or open menu settings.
Ive download it key map editor, changed the buttons and nothing.
Does anyone knows a workaround?
Thanks in advance
I think keyboard.xml or some other file needs to be edited. It is on my todo list for a long time but I don’t use BD so it is just waiting.
I think there are some guidlines on kodi forum where you should get more help.
Maybe something like this: osmc/package/mediacenter-osmc/patches/all-134-add-bdj-keymap.patch at c935949f6338348f01cc2cafd6f3f8df1116295e · osmc/osmc · GitHub
