I have the Dual Boot Option With Android and Coreelec,
When I’m on Android and try switch system, I keep getting the Android Recovery Screen and the only way I can boot to Coreelec is to put the sd card in and it will boot that when I restart.
Not sure what’s causing the problem
I can boot into CoreELEC from emmc, it’s just when I go into android and try booting to CoreELEC from there. I have to use the reset button with a sd card to do it.
