i want to use my own remote for kodi coreelec instat of the orginal remote from beelink gt king.
It is an Toshiba G83C0008A210. All functions working but only the power on and power of button wont work. At the moment i use the orginal remote to power on and power off the Beelink, but i want to use my toshiba for that
Can someone help me?
I use this remote.conf at the moment
#this file is configuration for each factory remote device
# work_mode 0 :software mode 1 :hardware mode
# repeat_enable 0 :disable repeat 1 :enable repeat
# factory_code each device has it's unique factory code.
# pattern:custom_code(16bit)+index_code(16bit)
# examble: 0xff000001 = 0xff00(custom cod) 0001 (index)
# release_delay unit:ms.release will report from kernel to user layer after this period of time
# from press or repeat triggered.
# debug_enable 0 :debug disable 1 :debug disable
# SW MODE:
# bit_count how many bits in each frame
# tw_leader_act time window for leader active
# tw_bit0 time window for bit0 time.
# tw_bit1 time window for bit1 time
# tw_repeat_leader time window for repeat leader
# REG
# reg_base_gen set value for PREG_IR_DEC_BASE_GEN
# reg_control set value for PREG_IR_DEC_CONTROL
# reg_leader_act set value for PREG_IR_DEC_LEADER_ACTIVE
# reg_leader_idle set value for PREG_IR_DEC_LEADER_IDLE
# reg_repeat_leader set value for PREG_IR_DEC_REPEAT_IDLE
# reg_bit0_time set value for PREG_IR_DEC_BIT0_TIME
#amlogic NEC remote
factory_code = 0xff000000
work_mode = 0
repeat_enable = 1
repeat_delay = 120
repeat_peroid = 33
release_delay = 121
debug_enable = 1
key_begin
# KEY Code Key_Action Kodi_Action
0x59 116 #KEY_POWER power ON/OFF
key_end
