first of all, thank you to the developers for the amazing work in doing CoreElec, such a great system!
I properly installed the generic 9.2.8 with SD card on my GT1 ultimate “Fake ram”.
Everything works fine except the HDMI CEC which is causing a lot of perturbations in my system. I have a Denon receiver and a Panasonic TV to which I connect the Beelink, an Xbox and an Apple TV. The latter is the only source with CEC control active and it was working fine to turn everything ON & OFF until I started the Beelink…
I searched the forum and looked in Kodi peripheral settings, the LibCEC version is shown as “unknown” which seems strange to me. I tried enabling / disabling it but no effect.
I just want to completely disable the CEC, any thoughts?
I’ve looked into the settings as you suggested but the following ones are actually not visible at all : Device OSD Name CEC Wake-Up Auto Power On Streaming Path/Routing Change Active Route
|CEC|||These settings only apply if the hardware supports it!|
Do I need to install something to get these settings or is it really because the GT1 hardware does not support it?
The only menu in which I could find CEC related settings is in Input>Peripherals.
About the EOL announcement, I understand and I’m actually looking for a replacement box on the forum in case I cannot troubleshoot these CES issues but it seems that there is no perfect solution from what I can read.
