Looks a reasonably specced box apart from still being in the dark ages with a USB 2.0 port.
Supposedly Google Certified and with Netflix 4K support, so that probably automatically rules it out for CE if Android is to be the only manufacturer supported OS.
It’s not a bad price for what it is but I’d recommend waiting for another 7 days to see what the S922X device is that adamg said was coming out for €45, which from the SOC perspective, blows the S905X3 out of the water.
hi everybody, i don’t manage to turn the box completely off (led still on) using Kodi power off buton. I have to switch the power off and turn the power on to start coreelec for a new session. how to fix that ? thank you. i’d like to use the box like a simple android box . thank you for you help.
