Reboot it? (unplug power if it’s stuck)
Is Aura definitely supported by Leia ?
Seems from scanning the Kodi Aura thread that its a common problem with Leia. Time to try another skin me thinks.
Hi! Which one is better/quicker to run system: use usb3, or quick sdcard in the sd slot , for CE installation in GT-King? Thank you
USB3 is faster, but runs hotter than uSD card.
Can i install coreelec to an external hard drive and boot from it
I don’t think I ever tried it, but it should work, since you can boot from USB.
rufus doesnt see hard drive
is there software i can use to install coreelec to a external hard drive
Etcher: https://www.balena.io/etcher/
This is duplicated, already solved in other topic.
I have usb 3 pen with 90/70MBps and sd card class10 with 100/95 MBps ordered. Thats why I ask. When use the usb 3 pen, I will lost one usb port. I only want this just, when my sd card would be really slower to run CE. How can I decide? Measure the boot speed?
Yes, boot speed is an indicator, or system update speed, or copying big files to/from media to USB HDD…
Hi .Just installed it with dtb rev.a When I reboot from coreelec it starts in Android.Am I doing something wrong ?How do I boot in coreelec ?
