Any DV licensed Amlogic device running CE-NG can play DV FEL (s922x/z, s905x2, s905y2, s905x3, s905x4, likely several others). The AM6+ is not unique in this regard.
One could argue that the Minix U22XJ Max is better than the AM6B+ since it matches all the specs, AND has an unencrypted bootloader.
One could argue that any of the s905x4 boxes are the best because they can play DV FEL, and also have AV1 HW decoding.
Aw ok. I didn’t realise. What does the unencrypted bootloader add? AV1 isn’t really relevant to me. I just play lossless rips. There’s no need for me to use it.
I have an Apple TV which I use for any other streaming use. It’s very slick and capable. My Ugoos is solely my Plex client for movie playing only but I’m more than happy to pay out if there’s something better for my use case.
These SOCs use video HW decoding, Plex video playback of bluray rips isn’t a challenge for any of these boxes.
CE is a minimal OS with low hardware requirements. The s922x/z is significantly faster than the s905x4. However, in use under CE, the difference is not that noticeable.
An unencrypted bootloader allows use of the bl301 injection tool. It’s a marginal difference, like many of the differences between all these boxes.
Apparently all hopes are finished for the S928X-J, Minix team could not get FEL to work, they finished by going down to HDR:
" Patching FEL Dolby Vision support (requested by some of you before, we seriously fight for this) - DONE, FEL will be played as HDR"
" Here is an update of our work in progress of the 002 firmware:
1.) Adding Auto Refresh Rate Switching module (new users may not realize that MINIX invented this feature on Android boxes)
DONE
2.) Auto frame buffer switching (19201080 for resolution within 1080p60Hz, and 38402160 for resolution of 4K or above, this is a new feature targeting enhanced app compatibility)
DONE
3.) Disney+ app compatibility (it’s a Disney+ app bug but we shall make it compatible, now it can be signed in using a smartphone within the same network, but its “Log-in” tab is buggy, haunted by a wrong DPI preset)
Cancelled, to fix this app’s flaw would cause many other problems
4.) More advanced HDMI-CEC features
DONE
5.) Better remote support in the advanced settings interface (tablet settings interface, not frequently used, but we shall make it better)
DONE
6.) Improved Settings description (fixing some spelling mistakes, e.g. passthrough, and adding a few new settings options, etc)
DONE
7.) Patching FEL Dolby Vision support (requested by some of you before, we seriously fight for this)
8.) Improved AI-PQ/AI-SR demo mode, added a green line for easy visualization of AI mastering/upscaling
DONE
9.) Adding “Close all” running apps tab in the app drawer interface
WIP
10.) Split-screen function (need airmouse/mouse to adjust the screen sizes)
WIP
11.) Kodi mouse/airmouse focusing issue (it works fine with remote navigation in the current build)
DONE
12.) Kodi native passthrough option (no need to manually choose the 2nd passthrough option)
DONE"
What this mean?
No 8.1 conversion?
It depends - there are movies like Saving Private Ryan where discarding the FEL layer ruins the quality, and some movies where the FEL layer seems to contain most of the film grain look. But yes, there are cases where it doesn’t necessarily offer that much.
Seems like it but this is all for android. CoreELEC will work as previously.
This video explains what are the benefits of FEL Dolby Vision Profile 7:
I thinks is from @R3S3T_9999
IMO I think it´s better to have it. (Even when there´s movies that doesn´t show any improvement).
Yes right, but thats mean, they havent got a newest dovi.ko, and therefore no chance to more device use the proper fel passtrough in CoreElec .
Cheers, could then CoreELEC eventually work on Ugoos AM8/S928X-J as it does on AM6B+/S922X-J, including P7 FEL, real tv-led? Anyways, just to make sure, I have a minix u22-xj on the way to me. Thanks.
Nope, not until Amlogic decides to enable FEL support.
Thank you.
Not Amlogic, it’s Dolby Laboratories.
And the decision is make.
From the looks of things I hope Ugoos won’t discontinue AM6B+ anytime soon.
they won’t as it still sells as hotcakes.
I wonder if they’ve figured out why?
they know about it.
Hello, just saw your post here.
Best device there, “and a lot more new devices now” such as…?
Thx!
The unencrypted bootloader on the Minix boxes, there’s two of them with the Amlogic S922XJ, the Minix U22XJ and the Minix U22XJ Max, allows you to, for example, have the usb ports always on or turn them off when you turn off the box.
S905X4 Dolby vision licensed devices. They have to use the 4.9 kernel. Homatics box r 4k plus is. Popular device here.
