When going to purchase the AM6 plus I see two options the AM6B Plus and the AM6 Plus. Which one is the right one or the better newer option?
Cheers, mate. The AM6B plus. Larger memory and storage.
@iMediaPi my $89 am6b+ arrived with the free remote
In terms of efficiency or technological advancement these boxes are not up to CE because they all have some limitations and we all know why (Dolby or FEL or AV1 and very soon h266…). When I asked which box to buy I am disappointed to see that the offer is not up to the excellent CE that is what I wanted to express. This is why I will stay with my 905X3 and I will look for something else for my multimedia system if there is no major progress on these boxes.
CE = 10/10
Android box = 3/10
Android box + CE = sometimes 10 sometimes 0 mean 5/10 ?
sorry I doubted you. brilliant offer and congrats
If my memory is correct, S922X-J has more powerful performance?
And by the way, is there any chance a even more powerful chip than S922X-J supports such feature? Such as S928X? I saw MINIX post that they intended to add FEL support for S928X in OTA update October, however, it seems that the update still hasn’t been released till now.
S922X-J is much more powerful, no, FEL for S928X won’t happen.
The Minix team have give up on FEL support I believe. Somebody mentioned this here on the forum.
Thank you! Hope you find a deal just as good, or at a lower price. It was actually $77.9 pretax (15% VAT).
They tried but Dolby Laboratories stopped support for FEL after 4.9 kernel. That’s what we have to live with. I’ll keep my U22X-J frozen for FEL support and will use other device as daily driver.
*** (Portisch
CoreELEC Team
1d
Not Amlogic, it’s Dolby Laboratories.
And the decision is make.)***
This should end the debate RE: FEL for the future.
I really like the X96X10 PRO S928X-J 8/ 64
Everything working
Ethernet
Wifi
Bluetooth
Front Display
Dolby Vision
If you use Android side
It is also working great
Boolloader is open
Factory Firmware is fine for daily driver with working Dolby Vision and Adaptive HDR
Also custom firmware (slimboxtv) available if one desired
*** This is a copy n paste from Portisch Post
What does the custom slimboxtv firmware add?
Android TV interface and apps.
Yes
Correct
And also AOSP version if desired
A post was merged into an existing topic: Help, support CPM build
Dolby vision FEL isn’t working on the 928 so any movies with FEL simply aren’t displaying correctly.
I know both AM6B PLUS and U22X-J feature S922X-J, but which is better overall?
minix has a slight edge overall, but good luck finding it (esp for a reasonable price) since it’s been out of production for a while. In my neck of the woods I’ve seen only a used one for around 200 eur on ebay (not available anymore), while I got my am6b+ for 120 (and it is not slouch either where it matters)
I found it on ebay.com two weeks ago, its on its way to Romania. Pardon our interruption...
I see. Hope you noticed that this one is more like am6+ (not am6b+) without WiFi 6. U22-xj MAX version is the last iteration with WiFi 6 and I think power update so it can give more juice via usb.
