Hi - I’m wondering what are the recommendations? I’m interested in both DVBT2/S2.
I know the MeCool KI Pro and KIII Pro seem to be working with CE and recommended, but I’m not sure if the S912 might be an issue though since I recall something about that chip might not be supported after Leia? (Can’t find the ref currently) Or even whether the more powerful cpu is really needed?
Alternatively I caught sight of the fact that a USB DVBT dongle may work since drivers may be present in CE e.g. the Astrometa one. Might this be better (certainly cheaper!) plugged into a normal S905 box?
KI Pro is S905D. Using it with DVB-S without any problem. For DVB-C you need a strong signal though. DVB-T/T2 might be a problem due to RF interference caused by the device itself. I myself cannot receive some DVB-T2 channels with coreelec that work with android.
Wetek Play 2 has only a DVB-S or a DVB-T/C tuner, but the tuners are quite good
Useful info, tx.
Is it possible to find out which tuner drivers are included with CE?
The ideal would be one of the twin tuner ones for simulataneous watch & record (the Xbox One ones are single tuner).
