In general my coreElec installations have been stable, but from time to time I run into a corrupted video database, or want to upgrade to a better SD card. My media NAS servers have 1700 movie rips and 4100 television series episodes, so the kodi video library is getting pretty big, and is a pain to have to rescan whenever the video database gets corrupted or a fresh installation is used.
Details:
stable S905x3 running CoreELEC-Amlogic-ng.arm-9.2.3.95-Generic nightly on a scanDisk class 4 4GB SD card. Installation is setup to boot from SD card with the kodi data on the internal emmc following these instructions: How to boot from SD/USB using internal storage for data
recently upgraded 9.2.x stable to 9.5 stable on a Minix _neo_u9h box using a 2GB generic SD card (slow so probably class 4 or lower). Boots from SD card & stores kodi data on SD card.
I’ve been having problems deciding on the best way to backup these working coreElec installations, I thought that making a dd image of the SD cards from a mac that can read SD cards would be a pretty easy way of doing this, and would grab any customizations made for booting prefs; but this process doesn’t seem to be stable.
I made a dd image of a 4GB SD card with the working CoreELEC-Amlogic-ng.arm-9.2.3.95-Generic nightly installation used to support a bqeel S905x3 quad-core 64bit dual wifi, GigEthernet, 4GB RAM, 64 GB ROM (emmc) box, and a dd image of the 2GB SD card with a working CoreElec-9.5 install supporting a Minix _neo_u9h box.
Both dd images of the SD cards were copied over to 32GB class 10 cards, and both of the 32GB SD cards booted into coreElec when installed in their respective android boxes. However initial testing of the 32GB SD cards indicates the installations don’t seem to be stable. When I remove power from the devices, the SD cards are getting corrupted. The 9.5 install on the Minix box had a corrupted video database after rebooting when power was applied, and the 9.2.3.95 installation on the S905x3 wasn’t able to read the kernel.
I use the following steps to write the previously saved images to the 32GB SD cards;
sudo diskutil umountDisk /dev/diskx with x being the disk# the SD card gets mounted as on the mac; in my case /dev/disk1
sudo dd if=/dev/zero of=/dev/rdisk1 bs=1024 count=1
sudo dd if=./Bqeel_CoreElec-9.2.3.95.img of=/dev/rdisk1 bs=4m for the S905x3
sudo dd if=./Minix_neo_u9h_CoreElec-9.5.img of=/dev/rdisk1 bs=4m for the Minix_neo_u9h
cd /Volumes/COREELEC
cp device_trees/sm1_s905x3_4g_1gbit.dtb dtb.img for bqeel
cp device_trees/gxm_q200_2g_minix_neo_u9.dtb dtb.img for minix
sudo diskutil umountDisk /dev/disk1
After writing the previously saved dd images to the SD cards a second time, I was able to get both of the boxes to boot into coreElec and working fine, but after a shutdown and removal of power of the Minix box, the subsequent reboot when power was reapplied wouldn’t boot into the coreElec installation on the SD card. I could boot into stock android OS when the SD card was removed, and am able to boot into coreElec using the original 2GB SD card.
The 9.2.3.95 install on the S905x3 seems to have survived at least one power down/power up cycle fine. Going to keep testing to see if it remains stable.
I’d like comments on if the process I am using should produce backup images that are stable, or if there is a problem with the steps I’m using. One problem with using this process when going from smaller SD cards to larger ones is that the copied image won’t utilize the extra space available in the larger SD card for the storage area. If I can get a stable way of making these backup images, then I’ll just do a fresh installation on the 32GB cards and then save backup images of them.
Also, if there is a better way of accomplishing what I’d like, maybe using the backup/restore functions in coreElec, I’m open to using them. I tried backup/restore before within coreElec before, but ran into some problems getting the restores to work, and using backup/restore requires modifying the partition names for the devices using emmc to store the kodi data. If the consensus is this is the way to to go, then I’ll spend more time working on using coreElec backup/restore.
Thanks,
