Hello, these are the best rated SDXC cards I have found:
-SanDisk 64GB Extreme PRO 200 MB/s UHS-I Class 10 U3 V30
-SanDisk 64GB Extreme PRO 300 MB/s UHS-II Class 10 U3 V90
-SanDisk 64GB Extreme PRO 300 MB/s R / 300 MB/s W UHS-II Class 10 U3 V90
I don’t know much about cards, so I ignore if it will be better or worse or if there will be any CoreELEC compatibility issues depending on the card:
UHS-I or UHS-II
V30 or V90
64GB or more
200 MB/s or 300 MB/s
I want the best possible CoreELEC performance with 4K UHD movies, without playback problems or any kind of failure.
Which one is the most recommended? Is the first one enough? If a more expensive card really improves performance, I would have no problem buying it.
Though I use CE on the internal memory I have had this question of which rating is more beneficial for ce given we have ratings like ‘a’ rating such as a2(which benefit random access) or ‘v’ rating like v90,etc (for sustained performance)
I was thinking of trying CoreELEC on an Odroid C4 or maybe a Mecool K5. I’ve almost ruled out the latter because I’ve read a lot of bad reviews about the performance of this device.
