I have s905w android box 1gb version i installed core elec and Netflix can anyone tell the the best settings for smooth playback some times frame skipping happens please any pros help me thank you
The S905W is an underclocked S905X, it’s pretty weak.
So 720P should work for most cases, but probably not all of them, then you’ll need to drop to 480p.
Usually “some frame skipping” is caused by 2 reasons, network bottleneck or impotent CPU
Try in Netflix settings under Expert settings - Use VP9 => ON. This should solve network problems, and if skipping still appears, then 480p is your only safe resolution.
