Bluetooth Volume Problem
Hello Everyone,
Odroid N2 with CE 20.1.
I’ve paired my BT Jabra Ear Buds to the N2 and they are working but the volume level is really low even though the N2 Volume is at 100%.
The volume controls on the Jabra’s does not seem to do anything either.
This is the dongle I’m using.
Is there anything else I can do to increase the volume?
TIA
EDIT:
N2:~ # lsusb
Bus 002 Device 002: ID 05e3:0620 Genesys Logic, Inc. GL3523 Hub
Bus 001 Device 004: ID 20a0:0006 Clay Logic flirc
Bus 001 Device 003: ID 0a12:0001 Cambridge Silicon Radio, Ltd Bluetooth Dongle (HCI mode)
Bus 001 Device 002: ID 05e3:0610 Genesys Logic, Inc. Hub
N2:~ #
EDIT2: I believe the Chipset to be BR8651.
I have just done some more testing.
Installed the Hardkernal Ubuntu image onto an SD rebooted and played the same music into the same headphones using the same BT Dongle and the audio was much louder.
Seems something in CoreELEC is affecting the BT Volume.
Ideas and thoughts would be appreciated.
TIA
