So I have videoprocessor/capture card in my setup to run MadVR and it does not support 12bit color. Every time I switch to my KODI box, it boots up in 12bit mode with an error message (YUV 4:2:2) and requires me to either:
- Unplug HDMI cable and it resets to 10bit (as set in system settings)
- Use the KODI app to go into system settings and set the color/refresh rate.
Is there a way to set my boot parameters to only boot in 10bit color?
I am using CORELEC with KODI 20.1 on a ODROID N2+
I have manually set it to 10bit color in the system settings.
