I would like to boot CoreELEC which is on an SD card in a Transpeed Amlogic S905X4.
→ https://fr.aliexpress.com/item/1005003620375696.html?spm=a2g0o.order_list.order_list_main.11.12935e5b6pw9LW&gatewayAdapt=glo2fra
I can’t find a “reset button” like on other boxes. So it’s impossible to boot with the “toothpick method”.
Which method do you use to boot on SD card with CoreELEC?
@LITUATUI → If you come by here, I’m sure you’ll have a solution for me.
Thank you!
