Its a better bet to keep your dvb seperate from your server/client boxes. This gives you reliability and future proofing against drivers becoming stale.
Not satellite here but also followed the external tuner path. I setup a hdhomerun expand quadtuner for dvb-c as sat>IP in tvh. Perfect. Now I use the usb tuners and vtv board for testing.
Just looking for a simple replacement should the current Kii comes to the end of its life… nothing fancy.
It’s on 24 hours and the heat sink is coming loose but is has been flawless for about 2-3 years, I don’t really touch it bar the auto updates. It running about 85 degrees
Looking to create a backup on CE, get new box, install CE on the new box, restore CE file, get on with my day for the next 2-3 years! Might just pick up another Kii… was just wondering if there was anything else like it out there.
If its just the heatsink coming lose then it should be really easy to reseat it.
Open the box.
Prize off the heatsink.
Clean the chips and the heatsink with alcohol or nail varnish remover.
Glue it back on , I use threadlock red to attach heatsinks, but real computer thermal past would be better. Threadlock acts as a glue but heatsink compound is not designed to glue well.
Put case back together.
