Finally, I was able to get another O2 box. I found out that I don’t have access to U-Boot commands, so I booted CoreELEC from the functional O2 box.
ls -la /dev/block/
total 0
drwxr-xr-x 2 root root 760 Mar 13 16:58 .
drwxr-xr-x 14 root root 4900 Mar 13 16:58 ..
lrwxrwxrwx 1 root root 10 Aug 6 2021 179:0 -> ../mmcblk0
lrwxrwxrwx 1 root root 13 Aug 6 2021 179:1 -> ../bootloader
lrwxrwxrwx 1 root root 8 Aug 6 2021 179:10 -> ../param
lrwxrwxrwx 1 root root 7 Aug 6 2021 179:11 -> ../boot
lrwxrwxrwx 1 root root 6 Aug 6 2021 179:12 -> ../rsv
lrwxrwxrwx 1 root root 10 Aug 6 2021 179:128 -> ../mmcblk1
lrwxrwxrwx 1 root root 12 Aug 6 2021 179:129 -> ../mmcblk1p1
lrwxrwxrwx 1 root root 11 Aug 6 2021 179:13 -> ../metadata
lrwxrwxrwx 1 root root 12 Aug 6 2021 179:130 -> ../mmcblk1p2
lrwxrwxrwx 1 root root 9 Aug 6 2021 179:14 -> ../vbmeta
lrwxrwxrwx 1 root root 6 Aug 6 2021 179:15 -> ../tee
lrwxrwxrwx 1 root root 9 Aug 6 2021 179:16 -> ../vendor
lrwxrwxrwx 1 root root 6 Aug 6 2021 179:17 -> ../odm
lrwxrwxrwx 1 root root 9 Aug 6 2021 179:18 -> ../system
lrwxrwxrwx 1 root root 7 Aug 6 2021 179:19 -> ../data
lrwxrwxrwx 1 root root 11 Aug 6 2021 179:2 -> ../reserved
lrwxrwxrwx 1 root root 8 Aug 6 2021 179:3 -> ../cache
lrwxrwxrwx 1 root root 15 Aug 6 2021 179:32 -> ../mmcblk0boot0
lrwxrwxrwx 1 root root 14 Aug 6 2021 179:33 -> ../bootloader0
lrwxrwxrwx 1 root root 6 Aug 6 2021 179:4 -> ../env
lrwxrwxrwx 1 root root 7 Aug 6 2021 179:5 -> ../logo
lrwxrwxrwx 1 root root 11 Aug 6 2021 179:6 -> ../recovery
lrwxrwxrwx 1 root root 15 Aug 6 2021 179:64 -> ../mmcblk0boot1
lrwxrwxrwx 1 root root 14 Aug 6 2021 179:66 -> ../bootloader1
lrwxrwxrwx 1 root root 7 Aug 6 2021 179:7 -> ../misc
lrwxrwxrwx 1 root root 7 Aug 6 2021 179:8 -> ../dtbo
lrwxrwxrwx 1 root root 11 Aug 6 2021 179:9 -> ../cri_data
lrwxrwxrwx 1 root root 14 Aug 6 2021 179:96 -> ../mmcblk0rpmb
lrwxrwxrwx 1 root root 8 Aug 6 2021 7:0 -> ../loop0
lrwxrwxrwx 1 root root 8 Aug 6 2021 7:16 -> ../loop2
lrwxrwxrwx 1 root root 8 Aug 6 2021 7:24 -> ../loop3
lrwxrwxrwx 1 root root 8 Aug 6 2021 7:32 -> ../loop4
lrwxrwxrwx 1 root root 8 Aug 6 2021 7:40 -> ../loop5
lrwxrwxrwx 1 root root 8 Aug 6 2021 7:48 -> ../loop6
lrwxrwxrwx 1 root root 8 Aug 6 2021 7:56 -> ../loop7
lrwxrwxrwx 1 root root 8 Aug 6 2021 7:8 -> ../loop1
dd if=/dev/bootloader of=/storage/partitions/bootloader.img bs=4M
dd if=/dev/dtbo of=/storage/partitions/dtb.img bs=4M
dd if=/dev/boot of=/storage/partitions/boot.img bs=4M
dd if=/dev/vendor of=/storage/partitions/vendor.img bs=4M
dd if=/dev/system of=/storage/partitions/system.img bs=4M
and copied the imgs to my PC
Which AmlogicKitchen scripts should I run? amlunpack.sh level 1, 2, 3 and then amlpack.sh level 1, 2, 3 right?
I did amlunpack.sh level 1 but I got this error. Could you help please? Thanks.
$ sudo ./amlunpack.sh
Amlogic Kitchen
Select level 1,2,3 or q/Q to exit:
1
Amlogic Kitchen
Files in input dir (*.img)
1 - boot
2 - bootloader
3 - dtb
4 - system
5 - vendor
Enter a file name :
boot
[Msg]Image package version 0x2144494f
[ERR]f(AmlImagePack.cpp)L298:Image check error! The magic number is not match
[ERR]f(AmlImagePack.cpp)L1635:Image file check failed!
Done.
Amlogic Kitchen
edit:
the headers look like this
my@pc ~/Desktop/temp/AmlogicKitchen-latest/in $ head boot.img
ANDROID!l�wandroidboot.dtbo_idx=0 androidboot.boot_devices=d0074000.emmc buildvariant=userNተ���l�9��#{����|���[}tSe���i
i�4��T�B�3���C�ަ**�@���9M)���c�TEi�)8⊻r۫hq�i�9Mf��B�������h .�uL
� ���+�R�>ϽI �A=[�99o�~<���}��s�ҁri�1����p嫠辕p��qݸn\7�y�T��{��o�Xκ�J9�t3H}x�4����\��6���oYγ��B��K#��}\�q���d�ğ3k���^�'��6T�������
'�� Y�Q�� !�����ű�¿wm����
65ԛ������|�Pߐ���6�aZk��XS6ɒ�"�?C}��j߫▒��
)��,���h� �$�}���9�����������V Whz�,���<
��Y�ߵ��]�z�B���w���l@�K}�l�R��{���e�F�J��Ɖ�O�����.�[�/�E�8����ٮo�h��▒���`�{ v=8;�tD����O{�d�̍,[
���Uf�� ��A��ĵ�v[�����n�w�v��n#�����~��`����EƘc�����~Z̹�������������1�L�g�}�2v��5��ܪƑn4�1��F*���}�.������c#�{/�k}c�G?���\�I�9��f��)f���.�A���t������3�X�·!:��>��m���:(�t���\l�q׀�W}����ʑ�iE9H@▒-/0!��Q��
WR�yw���U��u!M�'��@��t�� �wE俑��
�v����x��(�!N���}�3Oc�)�'���@�E�F*���2�T�_.o2H���d���
���`�*B{�h�n���x�/�[��)F����\���)���x�G�6�o�]���(�0��]���U�~�����Z;�tm\�&�Zg��xy�/�p�j#%^�I�Ê]���g��#rVb���q#��TlA8�D��</g}X����i��)������L���,�+�
��|�%�Q�ض���Nc��] �C�.���������������6�i]�.��ňI �+����p�*G��C�A▒����n����▒�Ot!?IJQ�w�v�`f#b�B< Gi��▒��7[���2�wF��w�A=v"����/�R�l�I��
e��m�e0B�y!9����8l��K�XdD��1�Vl(X����
��n�ͱ��5Vs�3R�w��QnhC���G��t\��^)!|t�Z�'�~�<Y
(S
e/
\;7ėxuI��ą�±z�Xȃ�U��D��`NvX���!,��6��������/�/?ߕi�_WD� ��b����������p�����uIf��^�WH�NƋ]h�
�'0U�:��,zhUɞ�k▒�g�E�w��Z�B-�� �����v\��|ZkƵ���2��[�X�WG^�8��q����O��l�<�����Y(�|��Ljibd����럭��
�z�i.�B����� f{X���RV��y��U�q�w��=�Ҹ��n�1�,��|i�ieN�c3�l>V8���q G�p���o��&��Xq����T�kA���/�_�i�c6�B���
��*����X���yH�(�5iP��O
U|��#�Lo�/9�Mz�PG@�M�hĕ�K�⥯ZJ9^r����S�}�����F�O#�-�u0,[M��|RB���9�a��1_�ʼnr�,�U�=W��`�
��~7y}�<�����(�6�'���h
�Yno�='�E�����C�G�mc���h�C�w�_�m�k�§�����l�`/�=�������a����
��S#���-▒���F��7'��e~��g��}n�w�C�������?Lr�c����x�Ϫ�����$A�s�O��̽��ǘ0�> 0����X��,Zv�ѝ�G���;�i�r��簼�Y�7-�=��Y�������Z�����K9u�����8�_=���g�/�3�b���?Î/��q�_=���5��ә���;�����Ǚ�~�����1��N`ܧ
����l�8\]kg'+��qxoe��C��ܡǟ
▒▒hي�?�=9�|�tnU�ocx�����l>�o�υ����_S���=��5��������5�}�x�{���
��p:O�2�}-c� ���4n�^�3n�^'��� �M��ރ2x����9G���g?��;���;�Cgs����:��%:��:�����֛�#�#�}Ϭ����5�M��▒�K�u �o�w�1 ��S�r�-Xrn�}|'π}hxu���>6�N����N Eqp�G o���n���?a,~�����s�G�d��e��C��0V;q�
�n�^>����Z.�� �>���1b�M�������g�#�ۛ��%Q`���%�y`�E��9ʳG-/�QF��Wg����!� �'�T <e�>�E����nH}��L�ݥD��(�{u*�b�Ȩ�.��K�i�^�íf5^?��)�7�E�<�)��Uu����&
my@pc ~/Desktop/temp/AmlogicKitchen-latest/in $ head bootloader.img
Bsc�t���$�ZDJ��n��#p!�����=#2����u▒^��{C���.J8�T\��� �q�?�*��*���K�z�▒�~��'�i6ժ�b��3V'�O�^�/ۦ�:���3��2#j���;{V�h��-l��8�6O�
���bQ\Nl�1�4>��4�:��Ջ/�A\YOx�L�S�D2��_�'��j��h�7�▒~R�����* sp�'�L\��$�u|s��
p̂�'%�<%��`^/e▒�*����M��%+|u�*֮7��f��▒�J{�a�▒��d��IsRs���X�:F7<��D̕�M�▒Y�. cn{���Fm9�c#"�V%�Yda?����'�f#j$؋P$�3}
Az�H�j¬���` ��$�k��sN% ���;_��>�Z�L��2凱���N��,T�
@�*� �v�=���<g{͚�b�L42*w��M�\���T�aG9��5H�d�n[���~��{>h���Iɣ �̥uM@3���Yv��m-�$��>и�i�=����;���,�N�����/ i�-w���h����2ר�P��%�'D����V'98����<
���d��KؠE�D�K�r.�-9�m�� ��_����t$P�ʤnS<�9"QJ/+Fh9�z�in#�V��9;�N�U����Qߔ5\�+��_��^HV���v�d�?�z��%hH{��}�~�!e�����W�sG6���5��L�3�Dh��g5���� �Fv)9LP��� �Uǘ?ISµm�
�d�q1�o�q-T%1���MT�ޟ{�f�A�Zynh)�Wɢ8|�]���V=C��L��g�����1�"_)�/▒X�:�妖�gaE:�~@Z.����LgD�I��O�����F<�u�wL�M35�▒>к�HT�����{���]�Ƭ�J�$j����bPK5n�Y�7|�(3r��^���&
�s"�9�L�T�+��{=f]+�q� �J��Lw}m����=����Sμd���▒1-NA�w$
.����]�C:��#+�5��~������Ϡ�i.�#3�J������3� �R���K�I���.�6�����:v- c
�GEU���ݖ�����+��/뀘�@�+pՆr�=�������F� �w������
��*�pQ▒GU,�ƚ��� ��aɈ�Mwi�/nt����Tڮ�Q硵�Y�=����.����͜��ph�u]�֥-r��rj�t�BTi1^�7����0���UQŕX2)�9 �� #4{�I��`}0�%|9
������JIJ�yՠ�;����L�ۆ1��K���V��ȠT������t�� �jh�]��M��eөM� yP�n&*,��9hu�"
�|]@���7��ڱ▒r��lۢ甖pA��G�▒�`{k�4��{l��p%)E\�˛�<1D▒լ#N���ߺ>_�K
C�.X��nV���6oV��A /�\ ���A�c�i,
��P;%�RX�A�� �sHR?��=�
/̕tg��Ժp��P�����1�*�rţ�-�����n�9tv���2hH+�__<�F�șB����/ap��k�K!o��� ��E�-mP
����s.���|���J�������-d��)$3c��fb�` }z�Q�|!?���TK>��n�1���
������5��U ������s�����Z�U١�|<�H����Q&.��K4�����wp�s`�s�l��EP$|▒�_����~F����A���WJ�auL���{���%ضA�(g��8OQ:#/]!� ��Ͳhx▒FUPɓ,�0���{8��/▒\nDS�.1����V�����,PUK�T�v�V��kC�ԦvI��6�s%#?̡< ��;��ކ�0wY~Jl�$��7�iʗ��*~▒I��k�]c[-Z�w��܉~Ȇۏ_��io�9�e�#��t��68�v��@����*�ps�6��3-':ߴq"M����{�D�H8m�s��Ҵ]&!�2 s7��\�C�F�eX���t�L��f7���9C�.L°m&']�l%��Q��������Z�/�{�������H��
�dzg�_E \[�!E�?r�A�i��s� ���WM
/G�E�k��b?̯� 8|�8 T�u���#=4��DAq�;^.c���aahV� ��N�B�ʕ���vAD�n�Z������KgV@���Y�9�67
my@pc ~/Desktop/temp/AmlogicKitchen-latest/in $ head dtb.img
��v8X( fragment@0/__overlay__dummy-battery
amlogic, dummy-batteryokayfragment@1/__overlay__dummy-charger
amlogic, dummy-chargerokay target-pathcompatiblestatusAVB0���avbtool 1.1.0��sha256 dtbofBO��y��-�v�NSgS"�SX6�wd�Ɗט0��y96�0�[|�▒+zr_}N��MP�AVBf�%
my@pc ~/Desktop/temp/AmlogicKitchen-latest/in $ head system.img
;����/����\I��S��\I
8B{G)c���\�� ����h<//N�w����^��3��څ�
�\I PQR^^3�P�Q�R���f����)P�Q�R������k�P�Q�R������ �P�Q�R����B�▒��-�P�Q�R�oi��>������������������������������� � � � � �
���������������������������������������������������▒�▒�▒�▒�▒������▒�▒�▒�▒�▒��0�0�0�0�1�1�1�1�1�2�2�2�2�2�3�3�3�3�3�4�4�4�4�4�5�5�5�5�5�6�6�6�6�6�7�7�7�7�7�8�8�8�8�8�9�9�9�9�9�:�:�:�:�:�;�;�;�;�;�<�<�<�<�<�=�=�=�=�=�>�>�>�>�>�?�?�?�?�?�@�@�@�@�@�A�A�A�A�A�B�B�B�B�B�C�C�C�C�C�D�D�D�D�D�E�E�E�E�E�F�F�F�F�F�G�G�G�G�G�H�H�H�H�H�I�I�I�I�I�J�J�J�J�J�K�K�K�K�K�L�L�L�L�L�M�M�M�M�M�N�N�N�N�N�O�O�O�O�O������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������\I�\I�\I�A�\I�\I�\I
�J �\I�Dselinuxu:object_r:rootfs:s0���@�\I�\I�\I�O �\I�A@�\I�\I�\I
�K �\I�Dselinuxu:object_r:rootfs:s0�A�\I�\I�\I
�P �\I�Dselinuxu:object_r:cgroup:s0�A�\I�\I�\I
�Q �\I�@elinuxu:object_r:apex_mnt_dir:s0��
�\I�\I�\I/system/bin �\I�Dselinuxu:object_r:rootfs:s0��2�\I�\I�\I/data/user_de/0/com.android.shell/files/bugreports �\I�Dselinuxu:object_r:rootfs:s0�A��\I�\I�\I�
my@pc ~/Desktop/temp/AmlogicKitchen-latest/in $ head vendor.img
�����k���~�\I��S��\I
8B{+�ŗ/^��Qĩ���nvendor/vendor�hq���Z���W���
�\I �,k{1k{C\����s~~������ �
�����������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������\I�\I�\I�A�\I�\I�\I�
�� �\I�@▒selinuxu:object_r:vendor_file:s0���@�\I�\I�\I�� �\I�A@�\I�\I�\I
�� �\I�@▒selinuxu:object_r:vendor_file:s0�A�\I�\I�\I�
�� �\I�<selinuxu:object_r:vendor_app_file:s0�A�\I�\I�\I�
�� �\I�<selinuxu:object_r:vendor_app_file:s0��z�-�\I�\I�\I�
��� �\I�<selinuxu:object_r:vendor_app_file:s0�A�\I�\I�\I�
