Buffering issues, no solution
I have a buffering problem on all my Remux (the movie pauses every 5min)
I’ve been trying a lot of things for a month now but I have no more ideas for a solution
I have the latest stable version of Coreelec and I also tried with the “nightly”.
My cache settings:
Buffer mode: all
Read factor: adaptive (i’ve tried on X10 but same problem)
Memory size:128MB
Chunk size: 1MB
I’ve already tried with many different settings…
The last thing I tried:
  • Read a remux on another support (USB 3.0 key): I was able to watch a whole remux without any problem but I can’t move forward or change chapters, the video freezes and doesn’t restart.
  • While with my HDD the movie cuts out every 5 minutes but I can move forward and change chapters without any problem
I don’t know how to do it anymore…
My equipment: Ugoos Am6bplus + Coreelec latest version on emmc + local HDD 3.0
Thank you very much to those who will take the time to help me
Thank you very much to those who will provide log and samples and how to reproduce.
No log, no error!
Does it work when played from SMB?
You are right, you will find attached the links with the debug log:
#1: https://paste.kodi.tv/lipareyike.kodi
#2: https://paste.kodi.tv/mabizenibu.kodi
#3: https://paste.kodi.tv/azocobevav.kodi
Explanation: I launch a remux on a USB key, the movie starts but I can’t fast forward, it freezes, I quit the movie. I launch the same remux on my HDD, the movie pauses at 7min02 then again at 12min37, if I do nothing the movie resumes by itself after ~1min. On the other hand, fast forward or by chapter works well with HDD
It does the same thing to me with all 4k remux
Thank you very much
Something is broken on your device or setup:
2025-03-03 12:18:23.139 T:4286    debug <general>: CDVDClock::SetSpeedAdjust - adjusted:0.000000
2025-03-03 12:18:23.139 T:4286    debug <general>: demuxer seek to: 1814967.931331
2025-03-03 12:18:23.139 T:4290    debug <general>: CAMLCodec::SetSpeed, speed(0)
2025-03-03 12:18:23.183 T:4291    debug <general>: CDVDAudio::Pause - pausing audio stream
2025-03-03 12:18:23.220 T:4290    debug <general>: CVideoPlayerVideo::OutputPicture - ttd:548ms pts:15.516 Clock:14.968 Level:5
2025-03-03 12:18:23.272 T:4290    debug <general>: CVideoPlayerVideo::OutputPicture - ttd:589ms pts:15.557 Clock:14.968 Level:6
2025-03-03 12:18:23.895 T:4290    debug <general>: CVideoPlayerVideo::OutputPicture - ttd:631ms pts:15.599 Clock:14.968 Level:6
2025-03-03 12:18:38.365 T:4097    debug <general>: Thread JobWorker 3787366912 terminating (autodelete)
2025-03-03 12:18:38.366 T:4096    debug <general>: Thread JobWorker 3803050496 terminating (autodelete)
2025-03-03 12:18:38.367 T:4127    debug <general>: Thread JobWorker 3591131648 terminating (autodelete)
2025-03-03 12:18:38.369 T:4095    debug <general>: Thread JobWorker 3746558464 terminating (autodelete)
2025-03-03 12:18:38.598 T:4120    debug <general>: PushCecKeypress - received key  b duration 0
2025-03-03 12:18:38.609 T:4033    debug <general>: HandleKey: 11 (0xb, obc244) pressed, window 12005, action is OSD
2025-03-03 12:18:38.610 T:4033    debug <general>: ------ Window Init (VideoOSD.xml) ------
2025-03-03 12:18:38.666 T:4120    debug <general>: PushCecKeypress - received key  b duration 69
2025-03-03 12:18:48.558 T:4120    debug <general>: PushCecKeypress - received key a8 duration 0
2025-03-03 12:18:48.575 T:4033    debug <general>: HandleKey: 168 (0xa8, obc87) pressed, window 12901, action is Right
2025-03-03 12:18:48.628 T:4120    debug <general>: PushCecKeypress - received key a8 duration 69
2025-03-03 12:18:50.519 T:4120    debug <general>: PushCecKeypress - received key  b duration 0
2025-03-03 12:18:50.538 T:4033    debug <general>: HandleKey: 11 (0xb, obc244) pressed, window 12901, action is Select
2025-03-03 12:18:50.538 T:4033     info <general>: CVideoPlayer::CloseFile()
You try to seek, then nothing is received anymore. Then you stop the playback.
No error.
Try again with other media, or with CE-NO.
CE-NG and CE-NE are final, no active development happen anymore.
