I Having a buffering issue when trying to play 2160p remux hevc file’s from local hard drive (USB 3.0). About 60gb for a each file.
The movie stop after 5 min to buffer and goes again and again.
Tried with 2 devices:
Mini m8s II - S905x 2gb ram 16gb rom
Ki pro - S905D 2gb ram 16gb rom
Same result.
Even changed the buffer size to 500mb with ares addon and still no changes.
Both your boxes probably have USB 2.0 ports. So if the data rate exceeds like 30-35 MBps, itll choke. I have a s912 box, usb 3.0 external drive and the max data rate is around 30-35.
I intsalled the latest version 8.95.1 (clean install - not an update) , and thought the dynamic buffer detection would solve the problem. so I made some tests:
the movies I checked are at a refresh rate of 23.976
All tests were performed on a local hard drive (USB 3.0 - WD my passport )
I tested the file’s on fullhd screen, but the buffering phenomenon also happens on 4K screen
