TV Box: Tanix TX9S
Specs: OS: Android 7.1.2
CPU: Amlogic S912, Octa core CPU
GPU: Mali T820MP3
RAM: 2GB DDR3
Storage: 8GB eMMC
Wifi: 802.11 b/g/n
LAN: Gibabit Ethernet 10/100/1000
USB: 2 x USB 2.0 + SD Card
SD card(CoreElec) - UHS - 1(10 speed class)
I recently installed the CoreElec 9.2.3 operating system (kodi 18.7.1) on a clean sd card and I thought I would get rid of the problem I had, but this problem remained. The problem is with starting an addon, when starting corelec, the addon is not started correctly, in the previous version coreelec 9.2.2 was the same. The addon on other platforms works ok, only the coreelec works nonsense, I talked to the creator of the supplement and he told me that the problem is not with him. The problem is not with him, when you stop the service and start it again, everything returns to normal, but after a restart to kodi (CoreElec) the same problem again.
You can test the addon on other platforms, it works ok.
After a restart of the service everything returns to normal, it can be seen in this kodi.log.
Add-on - link removed
In the log you can see how the service stop and start from 2020-06-24 15: 21: 27.080 T: 3637310272
Please solve this problem!!!
Kodi.log - link removed
