Bug: Playback Volume setting reset after restart
Now the log is complete and shows Kodi correctly stopped.
Which means we still have no idea what is going on :frowning:
I just went through the log myself and noticed the following suspicious line
DEBUG : UpdateAudioSystemStatus - CEC capable amplifier found (YAS-107). volume will be controlled on the amp
and wouldn’t you know it, after disabling CEC entirely and controlling Kodi via Yatse, the setting was saved across restarts / reboots. As soon as I enable CEC again it will be reset just like before.
Currently I’m just happy that the cause is now found and I’m not going insane as to why it’s not reproducible for others. But generally, I really like controlling the device with the TV remote and would like to avoid having an additional remote or using my smartphone…
So to rephrase the original issue then, is there any possibility to disable this “functionality” in the CEC adapter?
Big thanks to everyone helping out, especially @vpeter.
@freddy you were on the right track with your CEC suspicion.
Maybe have a look here?
I can’t see anything that might have an effect here. Or is it implied in any of the options available there?
Looks like this is not possible - sound is adjusted by amp and not Kodi.
I missed that.
