Bugs carried over from CE 9.2.5?
For a few weeks I have been saying that the best CE 9.2.x version is CE 9.2.5 for S912 devices. I also have S905X3 devices with amlogic-ng and I have been using CE 9.2.7 with which I also have problems related to the CE version. The problem is the following: I have a remote /storage/shared
directory mounted with sshfs (installed from entware) on all my CoreELEC devices where every day an automatic backup of each and every device is made on the LibreELEC server x86_64 with large storage capacity. Well, automatic backup runs correctly on all amlogic and amlogic-ng devices using CE 9.2.5 and stops running on devices using CE 9.2.7 and CE 19.1 Matrix (compiled: 2021-05- 12). If I run the backup script manually, then everything is fine. At first I thought this was caused by the sshfs mount options, but now I have no doubt that it is caused by the newer versions of CoreELEC.
Conclusion: Something is happening with versions after CE 9.2.5 and I would like to help you find the bug.
My question is: How can I activate debugging within a script and save the results before the device reboots.
Any other suggestions are welcome.
