Build CoreELEC in a docker container
Following this guide GitHub - CoreELEC/coreelec-builder and perform a “sudo apt-get upgrade” before “make image” i’m getting this error:
CMake Error at cmake/StdFilesystem.cmake:22 (message): Toolchain doesn’t support std::filesystem with nor without -lstdc++fs
I think there is a problem with the Ccache version 4.10.2. I’m not an linux expert. Can anyone help / update the guide please?
cert
You have to be more clear when you get this error.
I tested here locally and I see no issue.
