Build errors - downloading source files
Attempted to build a fresh pull of CoreELEC tonight using command:
DEVICE=Amlogic-ng make
Running into 400/404 errors when it tries to pull the source code for certain tools. First happened with “keyutils”, but I found a link that worked and fixed it. But now I’m having an issue with “connman” and figure there must be something going on.
--2024-05-04 21:23:58--  https://git.kernel.org/pub/scm/network/connman/connman.git/snapshot/connman-1cde7a6598a639d1f1eb16f7929f32919172ef10.tar.gz
Resolving git.kernel.org (git.kernel.org)... 139.178.84.217, 2604:1380:4641:c500::1
Connecting to git.kernel.org (git.kernel.org)|139.178.84.217|:443... connected.
HTTP request sent, awaiting response... 400 Bad request
2024-05-04 21:23:58 ERROR 400: Bad request.
Almost looks like it’s not possible to use snapshot downloading on git.kernel.org?
Looks like something wrong on server. But I copied file to CE server and should download it from there.
CoreELEC-22 Amlogic-no build error.
Ubuntu 22 (builds ng OK)
PROJECT=Amlogic-ce DEVICE=Amlogic-no ARCH=aarch64 make image -j4
1.log (9.5 KB)
Seems that there is a path problem or similar.
Try without -j4 because it is handled internaly.
Or use variable CONCURRENCY_MAKE_LEVEL.
Thanks…but no luck with either option.
As you can see, it gets through a couple of steps but trips out at openssl.
Packages loaded : 1023
Build trigger(s): 1 [image]
Package steps   : 349
<<< make:host seq 2 <<<
>>> make:host seq 2 >>>
[001/349] [DONE] build   make:host
<<< configtools:host seq 3 <<<
>>> configtools:host seq 3 >>>
[002/349] [DONE] build   configtools:host
<<< bkeymaps:init seq 4 <<<
>>> bkeymaps:init seq 4 >>>
[003/349] [DONE] build   bkeymaps:init
<<< openssl:host seq 1 <<<
BUILD      openssl (host)
    TOOLCHAIN      configure
Configuring OpenSSL version 3.3.1 for target linux-x86_64
Using os-specific seed configuration
Created configdata.pm
Running configdata.pm
Created Makefile.in
Created Makefile
***   OpenSSL has been successfully configured                     ***
/bin/sh: 1: aarch64-none-elf-/home/mike/CoreELEC/build.CoreELEC-Amlogic-no.aarch64-22/build/openssl-3.3.1/libreelec-local-cc: not found
make[2]: *** [Makefile:3382: apps/lib/libapps-lib-app_libctx.o] Error 127
make[2]: *** Waiting for unfinished jobs....
I don’t know what it could be because it works for everyone else. Try
DEVICE=Amlogic-no ./scripts/clean openssl
DEVICE=Amlogic-no ./scripts/build openssl:host
Er…finally reinstalled Ubuntu 20 and now have no problem. Seems it’s better to stick with your recommended options!
Now there is a problem with downloading fakeroot.
GET      fakeroot (archive)
--2024-07-29 16:55:58--  http://ftp.debian.org/debian/pool/main/f/fakeroot/fakeroot_1.35.orig.tar.gz
Resolving ftp.debian.org (ftp.debian.org)... 151.101.242.132, 2a04:4e42:39::644
Connecting to ftp.debian.org (ftp.debian.org)|151.101.242.132|:80... connected.
HTTP request sent, awaiting response... 404 Not Found
2024-07-29 16:55:58 ERROR 404: Not Found.
--2024-07-29 16:55:58--  http://sources.coreelec.org/fakeroot/fakeroot-1.35.tar.gz
Resolving sources.coreelec.org (sources.coreelec.org)... 116.203.16.118
Connecting to sources.coreelec.org (sources.coreelec.org)|116.203.16.118|:80... connected.
HTTP request sent, awaiting response... 301 Moved Permanently
Location: https://sources.coreelec.org/fakeroot/fakeroot-1.35.tar.gz [following]
--2024-07-29 16:55:58--  https://sources.coreelec.org/fakeroot/fakeroot-1.35.tar.gz
Connecting to sources.coreelec.org (sources.coreelec.org)|116.203.16.118|:443... connected.
--2024-07-29 16:55:58--  http://sources.libreelec.tv/mirror/fakeroot/fakeroot-1.35.tar.gz
Resolving sources.libreelec.tv (sources.libreelec.tv)... 65.109.172.87
Connecting to sources.libreelec.tv (sources.libreelec.tv)|65.109.172.87|:80... connected.
2024-07-29 16:55:59 ERROR 404: Not Found.
--2024-07-29 16:55:59--  http://sources.coreelec.org/fakeroot/fakeroot-1.35.tar.gz
--2024-07-29 16:55:59--  https://sources.coreelec.org/fakeroot/fakeroot-1.35.tar.gz
--2024-07-29 16:55:59--  http://sources.libreelec.tv/mirror/fakeroot/fakeroot-1.35.tar.gz
--2024-07-29 16:55:59--  http://ftp.debian.org/debian/pool/main/f/fakeroot/fakeroot_1.35.orig.tar.gz
--2024-07-29 16:56:00--  https://sources.coreelec.org/fakeroot/fakeroot-1.35.tar.gz
2024-07-29 16:56:00 ERROR 404: Not Found.
--2024-07-29 16:56:00--  http://sources.libreelec.tv/mirror/fakeroot/fakeroot-1.35.tar.gz
--2024-07-29 16:56:00--  http://ftp.debian.org/debian/pool/main/f/fakeroot/fakeroot_1.35.orig.tar.gz
--2024-07-29 16:56:00--  http://sources.coreelec.org/fakeroot/fakeroot-1.35.tar.gz
2024-07-29 16:56:01 ERROR 404: Not Found.
--2024-07-29 16:56:01--  http://sources.libreelec.tv/mirror/fakeroot/fakeroot-1.35.tar.gz
--2024-07-29 16:56:01--  http://ftp.debian.org/debian/pool/main/f/fakeroot/fakeroot_1.35.orig.tar.gz
--2024-07-29 16:56:01--  http://sources.coreelec.org/fakeroot/fakeroot-1.35.tar.gz
--2024-07-29 16:56:01--  https://sources.coreelec.org/fakeroot/fakeroot-1.35.tar.gz
2024-07-29 16:56:02 ERROR 404: Not Found.
--2024-07-29 16:56:02--  http://ftp.debian.org/debian/pool/main/f/fakeroot/fakeroot_1.35.orig.tar.gz
--2024-07-29 16:56:02--  http://sources.coreelec.org/fakeroot/fakeroot-1.35.tar.gz
--2024-07-29 16:56:02--  https://sources.coreelec.org/fakeroot/fakeroot-1.35.tar.gz
--2024-07-29 16:56:02--  http://sources.libreelec.tv/mirror/fakeroot/fakeroot-1.35.tar.gz
Cannot get fakeroot sources : http://ftp.debian.org/debian/pool/main/f/fakeroot/fakeroot_1.35.orig.tar.gz
Try later!
*********** FAILED COMMAND ***********
. "${get_handler}"
${SCRIPTS}/get "${PKG_NAME}"
${SCRIPTS}/unpack "${PKG_NAME}" "${PARENT_PKG}"
FAILURE: scripts/build fakeroot:host has failed!
Not anymore :slight_smile:
This is a new build.
Now like this:
GET      configtools (archive)
--2024-07-29 22:35:17--  http://git.savannah.gnu.org/cgit/config.git/snapshot/config-28ea239c53a2d5d8800c472bc2452eaa16e37af2.tar.gz
Resolving git.savannah.gnu.org (git.savannah.gnu.org)... 209.51.188.168, 2001:470:142::168
Connecting to git.savannah.gnu.org (git.savannah.gnu.org)|209.51.188.168|:80... failed: Connection timed out.
Connecting to git.savannah.gnu.org (git.savannah.gnu.org)|2001:470:142::168|:80... failed: Network is unreachable.
--2024-07-29 22:35:47--  http://sources.coreelec.org/configtools/configtools-28ea239c53a2d5d8800c472bc2452eaa16e37af2.tar.gz
Location: https://sources.coreelec.org/configtools/configtools-28ea239c53a2d5d8800c472bc2452eaa16e37af2.tar.gz [following]
--2024-07-29 22:35:47--  https://sources.coreelec.org/configtools/configtools-28ea239c53a2d5d8800c472bc2452eaa16e37af2.tar.gz
2024-07-29 22:35:47 ERROR 404: Not Found.
--2024-07-29 22:35:47--  http://sources.libreelec.tv/mirror/configtools/configtools-28ea239c53a2d5d8800c472bc2452eaa16e37af2.tar.gz
--2024-07-29 22:35:47--  http://git.savannah.gnu.org/cgit/config.git/snapshot/config-28ea239c53a2d5d8800c472bc2452eaa16e37af2.tar.gz
--2024-07-29 22:36:17--  http://sources.coreelec.org/configtools/configtools-28ea239c53a2d5d8800c472bc2452eaa16e37af2.tar.gz
--2024-07-29 22:36:17--  https://sources.coreelec.org/configtools/configtools-28ea239c53a2d5d8800c472bc2452eaa16e37af2.tar.gz
2024-07-29 22:36:17 ERROR 404: Not Found.
--2024-07-29 22:36:17--  http://sources.libreelec.tv/mirror/configtools/configtools-28ea239c53a2d5d8800c472bc2452eaa16e37af2.tar.gz
--2024-07-29 22:36:17--  http://git.savannah.gnu.org/cgit/config.git/snapshot/config-28ea239c53a2d5d8800c472bc2452eaa16e37af2.tar.gz
--2024-07-29 22:36:47--  http://sources.coreelec.org/configtools/configtools-28ea239c53a2d5d8800c472bc2452eaa16e37af2.tar.gz
--2024-07-29 22:36:47--  https://sources.coreelec.org/configtools/configtools-28ea239c53a2d5d8800c472bc2452eaa16e37af2.tar.gz
2024-07-29 22:36:48 ERROR 404: Not Found.
--2024-07-29 22:36:48--  http://sources.libreelec.tv/mirror/configtools/configtools-28ea239c53a2d5d8800c472bc2452eaa16e37af2.tar.gz
--2024-07-29 22:36:48--  http://git.savannah.gnu.org/cgit/config.git/snapshot/config-28ea239c53a2d5d8800c472bc2452eaa16e37af2.tar.gz
--2024-07-29 22:37:18--  http://sources.coreelec.org/configtools/configtools-28ea239c53a2d5d8800c472bc2452eaa16e37af2.tar.gz
--2024-07-29 22:37:18--  https://sources.coreelec.org/configtools/configtools-28ea239c53a2d5d8800c472bc2452eaa16e37af2.tar.gz
2024-07-29 22:37:18 ERROR 404: Not Found.
--2024-07-29 22:37:18--  http://sources.libreelec.tv/mirror/configtools/configtools-28ea239c53a2d5d8800c472bc2452eaa16e37af2.tar.gz
--2024-07-29 22:37:18--  http://git.savannah.gnu.org/cgit/config.git/snapshot/config-28ea239c53a2d5d8800c472bc2452eaa16e37af2.tar.gz
--2024-07-29 22:37:48--  http://sources.coreelec.org/configtools/configtools-28ea239c53a2d5d8800c472bc2452eaa16e37af2.tar.gz
--2024-07-29 22:37:48--  https://sources.coreelec.org/configtools/configtools-28ea239c53a2d5d8800c472bc2452eaa16e37af2.tar.gz
2024-07-29 22:37:48 ERROR 404: Not Found.
--2024-07-29 22:37:48--  http://sources.libreelec.tv/mirror/configtools/configtools-28ea239c53a2d5d8800c472bc2452eaa16e37af2.tar.gz
2024-07-29 22:37:49 ERROR 404: Not Found.
--2024-07-29 22:37:49--  http://git.savannah.gnu.org/cgit/config.git/snapshot/config-28ea239c53a2d5d8800c472bc2452eaa16e37af2.tar.gz
--2024-07-29 22:38:19--  http://sources.coreelec.org/configtools/configtools-28ea239c53a2d5d8800c472bc2452eaa16e37af2.tar.gz
--2024-07-29 22:38:19--  https://sources.coreelec.org/configtools/configtools-28ea239c53a2d5d8800c472bc2452eaa16e37af2.tar.gz
2024-07-29 22:38:19 ERROR 404: Not Found.
--2024-07-29 22:38:19--  http://sources.libreelec.tv/mirror/configtools/configtools-28ea239c53a2d5d8800c472bc2452eaa16e37af2.tar.gz
--2024-07-29 22:38:19--  http://git.savannah.gnu.org/cgit/config.git/snapshot/config-28ea239c53a2d5d8800c472bc2452eaa16e37af2.tar.gz
--2024-07-29 22:38:49--  http://sources.coreelec.org/configtools/configtools-28ea239c53a2d5d8800c472bc2452eaa16e37af2.tar.gz
--2024-07-29 22:38:49--  https://sources.coreelec.org/configtools/configtools-28ea239c53a2d5d8800c472bc2452eaa16e37af2.tar.gz
2024-07-29 22:38:49 ERROR 404: Not Found.
--2024-07-29 22:38:49--  http://sources.libreelec.tv/mirror/configtools/configtools-28ea239c53a2d5d8800c472bc2452eaa16e37af2.tar.gz
--2024-07-29 22:38:49--  http://git.savannah.gnu.org/cgit/config.git/snapshot/config-28ea239c53a2d5d8800c472bc2452eaa16e37af2.tar.gz
--2024-07-29 22:39:19--  http://sources.coreelec.org/configtools/configtools-28ea239c53a2d5d8800c472bc2452eaa16e37af2.tar.gz
--2024-07-29 22:39:19--  https://sources.coreelec.org/configtools/configtools-28ea239c53a2d5d8800c472bc2452eaa16e37af2.tar.gz
2024-07-29 22:39:20 ERROR 404: Not Found.
--2024-07-29 22:39:20--  http://sources.libreelec.tv/mirror/configtools/configtools-28ea239c53a2d5d8800c472bc2452eaa16e37af2.tar.gz
--2024-07-29 22:39:20--  http://git.savannah.gnu.org/cgit/config.git/snapshot/config-28ea239c53a2d5d8800c472bc2452eaa16e37af2.tar.gz
--2024-07-29 22:39:50--  http://sources.coreelec.org/configtools/configtools-28ea239c53a2d5d8800c472bc2452eaa16e37af2.tar.gz
--2024-07-29 22:39:50--  https://sources.coreelec.org/configtools/configtools-28ea239c53a2d5d8800c472bc2452eaa16e37af2.tar.gz
2024-07-29 22:39:50 ERROR 404: Not Found.
--2024-07-29 22:39:50--  http://sources.libreelec.tv/mirror/configtools/configtools-28ea239c53a2d5d8800c472bc2452eaa16e37af2.tar.gz
--2024-07-29 22:39:50--  http://git.savannah.gnu.org/cgit/config.git/snapshot/config-28ea239c53a2d5d8800c472bc2452eaa16e37af2.tar.gz
--2024-07-29 22:40:20--  http://sources.coreelec.org/configtools/configtools-28ea239c53a2d5d8800c472bc2452eaa16e37af2.tar.gz
--2024-07-29 22:40:20--  https://sources.coreelec.org/configtools/configtools-28ea239c53a2d5d8800c472bc2452eaa16e37af2.tar.gz
2024-07-29 22:40:20 ERROR 404: Not Found.
--2024-07-29 22:40:20--  http://sources.libreelec.tv/mirror/configtools/configtools-28ea239c53a2d5d8800c472bc2452eaa16e37af2.tar.gz
Cannot get configtools sources : http://git.savannah.gnu.org/cgit/config.git/snapshot/config-28ea239c53a2d5d8800c472bc2452eaa16e37af2.tar.gz
Try later!
. "${get_handler}"
FAILURE: scripts/build configtools:host has failed!
configtools are fine and must be something on your side.
