Hi All,
I want to use my trusty Minix Neo U1 elsewhere in the house and have been looking for a new box to run CoreElec. I came across the Buzz TV XRS4500 which has decent specs. I know I can run Kodi as an app from the Android interface but I really like using CoreElec as it gives the best performance.
Does anyone know if this box supports CoreElec? I did not see it listed in the download helper. The other box I was considering is the Minix Neo T5 which I know is fully supported.
Thanks in advance for any help
