Thread created to cater for off-topic posts.
Offtopic, but can you point one that you use with sucess?
Another would be one to delete subtitle files from movies already deleted… ![]()
Interested aswell, didn’t want to ask because offtopic
Kcleaner is adequate for me, but I have seen others ![]()
now you’re not (don’t get too used to me doing it though) ![]()
I like Kcleaner by DaLanik
There is an Addon called Fresh Start, but I am not sure if it is “dodgy”
I am not sure if this is better than the reset to system defaults under the Coreelec configuration addon
Or even just starting a new image on an sd card.
I use, Kcleaner
If this is for Kodi, Then, I installed TVAddOns plugins and used it to perform auto maintenance on my CE box.
