I have an 8GB SD card right now on my box which is a 2GB/16GB device.
I am satisfied with my install and I wish to make it permanent. The default OS on this device wasn’t even configured correctly from the factory since it is an A95X clone, and Android 7.x has long since been abandoned, so this will be an improvement.
Is 2GB emmc sufficient for this process or is 3GB the minimum (in which case I need to stick with the SD card)?
Thank you.
