As of 9.2.3 I cannot see my N2 on the network. Before it (most of the time, not always) registered itself as coreelec, now I can’t see anything (once I saw something like android-string-of-hexadec-digits, but don’t know whether it was N2).
I allocated IP address to the machine forcibly, and I can’t even connect to it via the IP address allocated - the connection times out (both trying to connect via SSH and via tvheadend port, and yes, I have ssh enabled).
Edit: The N2 box is on the network as it connects to my nas. it’s just I can’t connect to it/see it.
My TV headend is playing up, with Kodi refusing to delete (or even change) timer rules, and I can’t connect to it, which is causing havoc. So getting to the box is sort of quite important for me.
Any ideas?
Cheers,
Vlad
(As a side note, I have to say after almost a year, I’m pretty disappointed with N2. Out of three USB tuners I have, it sort of works with one. Kodi and TVH keep playing up in unpredictable ways, which often means lost recordings, although admittedly this could be Kodi/TVH but I never had these issue on Pi2).
