I can’t build coreelec ,Because of the following questions
Cannot get kodi sources : https://github.com/CoreELEC/xbmc/archive/6763f2c6ab3a5fcc8b75f683db13c6bda.tar.gz
We are aware of the the problem and it will be fixed shortly.
One of the ce developers just made a commit that should fix this issue. So if you pull the latest source it should work for you.
