Definitely not an issue of HDMI cables (tested brand new very good quality cables from HK1 Rbox x4 to Yamaha RX-A860 & then to TCL 43RC630K Roku TV)
General
Complete name : F:\Audio\!DD\Chameleon.m2ts
Format : BDAV
Format/Info : Blu-ray Video
File size : 610 MiB
Duration : 1mn 3s
Overall bit rate mode : Variable
Overall bit rate : 80.6 Mbps
Maximum Overall bit rate : 109 Mbps
Video #1
Menu ID : 1 (0x1)
Format : HEVC
Format profile : Main 10@L5.1@High
Codec ID : 36
Duration : 1mn 2s
Width : 3 840 pixels
Height : 2 160 pixels
Display aspect ratio : 16:9
Frame rate : 23.976 (24000/1001) fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 10 bits
Color range : Limited
Color primaries : BT.2020
Matrix coefficients : BT.2020 non-constant
Video #2
Menu ID : 1 (0x1)
Format : HEVC
Codec ID : 36
Duration : 1mn 2s
Width : 1 920 pixels
Height : 1 080 pixels
Color space : YUV
Bit depth : 10 bits
Audio #1
Menu ID : 1 (0x1)
Format : Atmos / TrueHD / AC-3
Mode extension : CM (complete main)
Format settings, Endianness : Big
Muxing mode : Stream extension
Codec ID : 131
Duration : 1mn 2s
Bit rate mode : Variable / Constant
Bit rate : 640 Kbps
Maximum bit rate : 6 183 Kbps
Channel(s) : Object Based / 8 channels / 6 channels
Channel positions : Object Based / Front: L C R, Side: L R, Back: L R, LFE / Front: L C R, Side: L R, LFE
Sampling rate : / 48.0 KHz / 48.0 KHz
Frame rate : 31.250 fps (1536 spf)
Stream size : 4.79 MiB (1%)
Audio #2
Menu ID : 1 (0x1)
Format : E-AC-3
Format/Info : Audio Coding 3
Codec ID : 132
Duration : 1mn 2s
Bit rate mode : Constant
Bit rate : 500 bps
Channel(s) : 6 channels
Channel positions : Front: L C R, Side: L R, LFE
Sampling rate : 48.0 KHz
Frame rate : 187.500 fps (256 spf)
Compression mode : Lossy
Stream size : 3.83 KiB (0%)
Audio #3
Menu ID : 1 (0x1)
Format : AC-3
Codec ID : 129
Duration : 1mn 2s
Bit rate : 640 Kbps
General
Complete name : F:\Audio\!DD\Core Universe.m2ts
Format : BDAV
File size : 979 MiB
Duration : 3mn 8s
Overall bit rate : 43.5 Mbps
Video #1
Menu ID : 1 (0x1)
Format : HEVC
Codec ID : 36
Duration : 3mn 7s
Color space : YUV
Bit depth : 10 bits
Video #2
Menu ID : 1 (0x1)
Format : HEVC
Codec ID : 36
Duration : 3mn 7s
Color space : YUV
Bit depth : 10 bits
Audio #1
Menu ID : 1 (0x1)
Codec ID : 131
Duration : 3mn 7s
Bit rate : 640 Kbps
Maximum bit rate : 9 621 Kbps
Stream size : 14.3 MiB (1%)
Audio #2
Menu ID : 1 (0x1)
Format : E-AC-3
Codec ID : 132
Duration : 3mn 7s
Bit rate : 500 bps
Stream size : 11.5 KiB (0%)
Audio #3
Menu ID : 1 (0x1)
Format : AC-3
Codec ID : 129
Duration : 3mn 7s
Bit rate : 640 Kbps
General
Unique ID : 185043870167063832638401480775770234360 (0x8B36272ECF36C8DB0F774CFB9A26DDF8)
Complete name : F:\Audio\!DTS\THX-2019-4K_DK_DTS-HD_MA_51_AC3_51-thedigitaltheater.mkv
Format : Matroska
Format version : Version 4 / Version 2
File size : 332 MiB
Duration : 1mn 7s
Overall bit rate : 41.1 Mbps
Movie name : THX - 2019 - thedigitaltheater.com
Encoded date : UTC 2019-08-20 20:57:49
Writing application : mkvmerge v30.1.0 ('Forever And More') 64-bit
Writing library : libebml v1.3.6 + libmatroska v1.4.9
Video
Format : AVC
Format/Info : Advanced Video Codec
Format profile : High@L5.1
Format settings, CABAC : Yes
Format settings, ReFrames : 1 frame
Codec ID : V_MPEG4/ISO/AVC
Duration : 1mn 6s
Bit rate : 36.8 Mbps
Frame rate mode : Constant
Frame rate : 24.000 fps
Color space : YUV
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.185
Stream size : 292 MiB (88%)
Default : Yes
Forced : No
Color primaries : BT.709
Transfer characteristics : BT.709
Matrix coefficients : BT.709
Audio #1
Format : DTS
Format/Info : Digital Theater Systems
Format profile : MA / Core
Mode : 16
Codec ID : A_DTS
Duration : 1mn 7s
Bit rate : 4 259 Kbps / 1 509 Kbps
Frame rate : 93.750 fps (512 spf)
Bit depth : 24 bits
Compression mode : Lossless / Lossy
Stream size : 34.4 MiB (10%)
Title : dts-hd ma 5.1
Language : English
Default : Yes
Forced : No
Audio #2
Format : AC-3
Codec ID : A_AC3
Duration : 1mn 7s
Bit rate : 640 Kbps
Stream size : 5.17 MiB (2%)
Title : ac3 5.1
Language : English
Default : No
Forced : No
None will play via Yamaha RX-A860, no matter what settings I use for depth or colour,TV just states No Signal
Dispinfo
http://ix.io/4EWX
If I plug OE HK1 Rbox x4 to HDMI1 input on TV directly, it plays fine, but of course I do not have any audio (because ARC is on HDMI2)
Yamaha is set to Mode1 already - Selecting the HDMI 4K signal format (4K MODE)
Anybody any ideas?
sebus
