he hello
again the same problem i had to reset coreelec but now my remote codes are not working.
i have a working map but i cannot put it in coreelec, i can connect with putty but wen i try to connect the box by my pc and put the ip adress from the box with :8080 behind i always see the chorus web interface
so it is impossible for me to put the remote codes in the box i using w10 pc trying for hours now but no succes please help
yes i know but the problem is a sold the box so the guy needs it now all shops are closed by corona and order one wil take to long
is it possible to put the files in the map by putty
Yes
You can use putty or You can use WinSCP
There are many options.
In my case I use ssh connect and VI editor, or/and WinSCP to copy some files
can you give me a little explane how i can put the files the easy way with vi editor thanks a lot
wel i installed winscp can you explane how to connect to coreelec
The same way like ssh connect
You need username/password and box IP adress
Maybe You read the documentation of WinSCP
wel i have found that and put the files in the wright folder but how to save the files in winscp
Two options:
- learning by doing
- buy a wireless remote control
well it worked with winscp great help thanks a lot have a nice day
