Hello there guys. I have just bought my H96 MAX X4 device and coreelec is working like a charm. Only one problem that I have: cannot switch off the device. Even I put it to sleep or switch it off it instantly switches back. I tried to switch the complete CEC off maybe something wake the device on but no luck. Tried two different remote controllers (maybe it ‘repeats’ key) and with the one I use for my magicsee/coreelec box (amremote) but no luck. Tried both KEY_POWER and use the menu for switch off. As I see inject_bl301 is not available (No bl301 binary for ‘Generic’ CPU type ‘SC2’ is found…) so I am lost. Maybe somebody faced this problem also?
The log contains not so much:
2024-01-05 12:50:43.077 T:836 debug : LIRC: - NEW 74 0 KEY_POWER devinput (KEY_POWER)
2024-01-05 12:50:43.092 T:832 debug : HandleKey: rewind (0xc4) pressed, window 10016, action is ShutDown()
2024-01-05 12:50:43.283 T:832 debug : LogindUPowerSyscall: Received PrepareForSleep with arg 1
2024-01-05 12:50:43.284 T:832 debug : ------ Window Init (DialogBusy.xml) ------
2024-01-05 12:50:43.284 T:832 info : OnSleep: Running sleep jobs
2024-01-05 12:50:43.284 T:1338 debug : Thread JobWorker start, auto delete: true
2024-01-05 12:50:43.284 T:832 debug : CApplication::CloseNetworkShares: Closing all network shares
2024-01-05 12:50:43.284 T:832 debug : LogindUPowerSyscall - delay lock sleep released
2024-01-05 12:50:43.447 T:837 debug : CLibInputHandler::DeviceRemoved - keyboard type device removed: input_btrcu (event1)
2024-01-05 12:50:43.466 T:832 error : Keymapping error: no such action ‘lirc.stop’ defined
2024-01-05 12:50:43.510 T:833 debug : UnregisterDevice - sending standby commands
2024-01-05 12:50:43.564 T:833 debug : UnregisterDevice - sending inactive source commands
2024-01-05 12:50:43.648 T:837 debug : CLibInputHandler::DeviceRemoved - keyboard type device removed: vad_keypad (event2)
2024-01-05 12:50:43.648 T:837 debug : CLibInputHandler::DeviceRemoved - keyboard type device removed: cec_input (event0)
2024-01-05 12:50:47.978 T:832 error : Keymapping error: no such action ‘lirc.start’ defined
2024-01-05 12:50:48.294 T:832 debug : LogindUPowerSyscall: Received PrepareForSleep with arg 0
2024-01-05 12:50:48.294 T:832 info : OnWake: Running resume jobs
2024-01-05 12:50:48.294 T:832 debug : ------ Window Deinit (DialogBusy.xml) ------
2024-01-05 12:50:48.325 T:848 debug : CAESinkALSA - Unable to obtain ELD information for device “hdmi:CARD=AMLAUGESOUND,DEV=0” (not supported by device, or kernel older than 3.2)
2024-01-05 12:50:48.328 T:848 debug : PulseAudio: Context authorizing
thanks.
manoo
