Can't access SSH (newbie needs help!)
Hi, all!
I am trying to access my (thanks, Santa!) new Ugoos AM6B+ through ssh so I can install CoreELEC as a dual boot to the eMMc (I already have CoreElec running via a thumb drive) and I keep getting this message:
”root@coreelec.local.: Permission denied (publickey,keyboard-interactive).
[Process completed]”
I think I might have borked the ssh on my Mac Studio at some point in my history and none of the solutions I’ve found online can fix the Permission Denied problem and give me access to ceemc in the Ugoos.
Please assume I know nothing about computing as I am just a Mac user who is just learning how to use Android and Kodi.
Thanks ahead of time!
This is how I connect via command line:
ssh root@192.168.1.67
The authenticity of host ‘192.168.1.67 (192.168.1.67)’ can’t be established.
ED25519 key fingerprint is SHA256:gk5qc1bWqlEQjDwgg62eH/DJByX+6NrnR1E9w4yBP3A.
This key is not known by any other names.
Are you sure you want to continue connecting (yes/no/\[fingerprint\])? yes
Warning: Permanently added ‘192.168.1.67’ (ED25519) to the list of known hosts.
root@192.168.1.67’s password:
Try this : open finder and go to folder and enter: ~/.ssh/known_hosts
Delete that file to reset all saved ssh
It’s still happening:
The authenticity of host 'coreelec.local. (192.168.1.240)' can't be established.
ED25519 key fingerprint is SHA256:UwkCdEi8ZD9Mr6y9asMQ0ocSon0BQDOvUl0aRAljc6Y.
Warning: Permanently added 'coreelec.local.' (ED25519) to the list of known hosts.
\[Process completed\]
I’ve deleted the “known_hosts” twice and I have had the same outcome.
did you try a thirdparty ssh client like putty? it seems to me that you use id_rsa.pub and what else instead of a simple quick username and password login
and i mean you use the id_rsa.pup on the client in the past and thats is causing you trouble
No, I used Terminal as instructed. I am on a Mac so I can’t use Putty, btw. I will look for other ssh apps for Mac, though. Thanks for the idea!
Termius worked! Thanks, all!
good to know :smiley:
