Hi all, I used to run 20.0 on my VIM3, installed via oowow, then used HAOS on the board for a while. I would like to install CE again, however there’s no oowow image for 21.0, and neither for the exciting amlogic-no nightly build.
I have flashed mainline u-boot on the eMMC, prepared 2 SD cards with both amlogic-ng and amlogic-no images, copied the right dtb, but the VIM fails to boot any of these. I also tried flashing USB drives, same result. I tried flashing android on the eMMC but that doesn’t let me boot CE either.
I can boot Armbian just fine from SD or USB, that I flashed the exact same way. Is anyone able to run CE on the VIM3?
